Formatting numeric values
    Is it possible to format a value in a numeric variable ? i.e. the value 3:
    in a Byte variable as 03
    in a 16 bit as 0003 etc.
    I noticed that the HS is stripping the leading zero away, although they are not significant, I would like to keep the format of the output in a fixed length format.
    I've looked in existing Baustein and in the Python doc, no luck
    (Formatting a text variable would be no problem).
    Thank you for any hint.
