New Logic: upgraded 18011 Light Scenes
    Hello,
    The 'old' Light Scenes logic: 18011 which is included in the Experte/Homeserver only support 5 actuators and 4 bytes per scene. I noticed this when I wanted to save a RGBW (6 byte) value. The idea of the Logic block is great, so I wanted to upgrade it.
    I made: 14361 - Lichtszenen v2.hsl (up to 8 byte, so RGBW)
    And it works fine!
    Is there any need to update​ this logic with other features?
    (like up to 10 actuator support? however, note that the block requires twice as much memory currently because it saves 8 bytes instead of 4 bytes per actuator, even if the actuators are not used. If I would make it to support up to 10 actuators, it will again use twice as much memory)
    I can image an option to Export/Import the data, maybe to a webhook? However, the remanent speicher of the homeserver can already be backupped automatically (using FTP).
    If no other features are requested, I will release the logic soon.
