Pet friendly motion sensor
    KNX/EIB Pet friendly motion sensor
    Anyone know of a pet immune motion sensor?
    I.e that you either can set the sensability or use a filter in front so the sensor wont trigger when the dog pass by (small one 51cm height)
    /Martin
    Is it possible in your situation to install the sensor upside down?
    Gruß, Rainer
      if you by that mean if its possible to mount in the roof, yes it is
        not to the roof, mount it as usual at the wall - just turn it 180°, so it 'looks' to the roof and doesn't trigger to objects below. only limitation is, u must be taller than the hight where sensor is mounted
          Ahh alright, im with you now
          Smart way, but I rather have one roof mounted or is there any Motion sensor that is really flat?
          /Martin
