Introducing the SCRIPTING Logic Node for Gira X1 and L1
With the SCRIPTING Logic Node you can combine calculations, text processing and custom logic into a single powerful block, replacing multiple formula, formatter and parser modules at once. It can do JavaScript (ECMAScript 5.1), LUA Script 5.4 and even (on X1 only): Python 2.7 with a lot of additional libraries like paho/mqtt, pymodbus, bacnet, urllib2, urllib3, requests, jinja2, flask and more!
The L1 can only do JavaScript and LUA Script, not Python, because it doesn't have enough resources.
Use STATE to keep a value between triggers of the same block. This JavaScript counter starts at 1 on its first trigger:
To share a value, run SHAREDSTATE.x = 10; in one block and read OUT1 = SHAREDSTATE.x; in another.
Build compact logic flows, reduce wiring complexity and create advanced automations with just a few lines of code. From smart data handling to dynamic text generation and complex conditions: everything runs inside one fast, flexible node.
Finally, real JavaScript/LUA or Python scripting inside your logic project!
This logic node crushes the Formelberechnung, Textformatierer, JSON-Parser and many other logic nodes with it's easy, flexible and lightweight use.
One block. Endless possibilities.
Write and keep your multiline source in a text file. In the script editor, select the language, paste your source and click the generated line to copy it. Select the same language in GPA and paste that line into Script. Pasting several lines directly into GPA 6.1 can leave only the first line.
The logic node has an Auto Update Check (during validation in the GPA) and during operation on the X1/L1 so you will get notified of updates!
Tip: Ask AI for a script (see below!)
Download for your device
X1 – JavaScript, Lua and Python 2.7
L1 – JavaScript and Lua
This Logic Node is now also available for Gira Homeserver, see here: https://knx-user-forum.de/forum/%C3%...tyserver-14362
How it works:
Send a value to Trigger to run the script. Zero and false also trigger a run. An input uses its configured default until it receives a value. If neither is available, the node supplies zero.
Each trigger sends the outputs. To send 1 when numeric IN1 equals 5 and 0 otherwise, set OUT1 explicitly:
To forward only changed values, connect a Send-by-Change block to the output.
Trigger the block when it received something at INPUT1? Do it like this:
(don't worry about timing issues, it will first fill the inputs and then trigger the block)
First test in GPA
Add the block to a test logic sheet. Select JavaScript, one input and one output. Enter the line below, set numeric IN1 to 4 and send a value to Trigger in the simulation. OUT1 should report 5. Enable Debug to see the execution time on Error Text.
Some Javascript examples:
NUMBERS
String manipulation (text)
LOGIC
JSON
Let's take the following sample JSON to explain:
Some LUA Script examples:
Use hysteresis for temperature control. OUT1 switches on below 20 and off above 22. Between those thresholds it keeps its previous value.
Remember the lowest (OUT2) and Highest (OUT3) values in memory and also have the average of those two (OUT1)
Some Python 2.7 + packages Examples (X1 only!):
Using external Libraries (pymodbus, paho (mqtt) and requests with json)
Read two holding registers. Replace the example IP address, unit and register addresses with those of your device.
Sending a message to a MQTT server with authentication:
Requests and JSON with Python:
You can even ask AI (ChatGPT, CoPilot or DeepSeek):
"Hello, can you generate JavaScript code for the Gira X1 Scripting Logic Module (see examples at https://www.roelbroersma.nl/scripting)?
I have 2 inputs and 1 output.
CHANGE LOG
v0.2.000000 (19-mar-2026)
v0.1.000025 (23-feb-2026)
v0.1.000024 (02-feb-2026)
v0.1.000018 (01-feb-2026)
STATE.count = (STATE.count || 0) + 1; OUT1 = STATE.count;
How it works:
OUT1 = (IN1 === 5) ? 1 : 0;
First test in GPA
OUT1 = IN1 + 1;
NUMBERS
OUT1 = IN1 * 1.19; // Multiply with Mwst. OUT1 = IN1 + IN2 + IN3 + (IN4+2) // Set Output sum. OUT1 = IN1 + IN2; OUT2 = IN1 - IN2; // Set multiple outputs in one time OUT1 = (IN1 / 255) * 100; // Devide and use ( and ) OUT1 = Math.round(IN1 * 100) / 100; // Math.round will always round on whole number, to have two decimals, device by 100. OUT1 = Math.min(Math.max(IN1, 0), 100); // Limit the Input between 0 and 100 OUT1 = Math.abs(IN1); // Inverse: -5 -> 5 OUT1 = -IN1; // Also 5 -> -5 OUT1 = Math.pow(IN1, 2); // (power of 2): IN1² OUT1 = Math.sqrt(IN1); // (taking the root): √IN1
OUT1 = "Hello there!"; // Set a simple text to Output1 OUT1 = "Value is: " + IN1; // Set combined text+value. Example: "Value is: 10" OUT1 = "My " + IN1 + " has " + IN2 + " homes"; // Concatenate Strings. Example: "My Son has 2 homes" OUT1 = IN1.toString().substring(0, 5); // Take the first 5 characters (start at character 0) OUT1 = IN1.toString().trim(); // Trim spaces if (IN1.length > 10) OUT1 = IN1.substring(0, 10) + "..."; // Shorten text to 10 characters + "..." else OUT1 = IN1; OUT1 = IN1.replace(/,/g,"."); // Replace all commas by dots. OUT1 = IN1.slice(-3); // Keep the last 3 characters
LOGIC
OUT1 = (IN1 === 1) ? 1 : 0; // Compare a numeric input.
var temp = IN1;
OUT1 = temp;
var i = 1;
OUT1 = this["IN" + i]; // Read IN1 using its input number.
if (IN1 >= 50) OUT1 = 1; // Use if else
else OUT1 = 0;
if (IN1==1) OUT1 = 1; // Use if, elseif, else
else if (IN2==1) OUT1 = 2;
else if (IN3==1) OUT1 = 3;
else OUT1 = 0;
if (OUT1==1 && IN2==0) OUT2 = 123; // Read the value of OUT1
switch(IN1) { // Switch Logic (easier than if/elseif/else)
case 0: OUT1 = "OFF"; break;
case 1: OUT1 = "AUTO"; break;
case 2: OUT1 = "MANUAL"; break;
default: OUT1 = "UNKNOWN";
for (var i = 1; i <= 5; i++) { // A FOR Loop
if (this["IN" + i] == true) { // The computed variable IN1...IN5
OUT1 = i;
break;
JSON
"device": {
"name": "LivingRoomController",
"status": "online",
"metrics": {
"temperature": 21.6,
"humidity": 48,
"power": 312.4
"modes": [
{ "id": 1, "name": "Auto", "active": true },
{ "id": 2, "name": "Eco", "active": false },
{ "id": 3, "name": "Boost", "active": false }
var obj = JSON.parse(IN1); // Read Input1 as JSON OUT1 = obj.device.name; // "LivingRoomController" OUT2 = obj.device.metrics.temperature; // 21.6 OUT3 = obj.device.modes[0].name; // "Auto" OUT4 = obj.device.modes[2].active; // false OUT5 = obj.device.modes.length; // 3 OUT6 = obj.device.status + " / " + obj.device.metrics.power + "W";
STATE.on = STATE.on or 0 local t = IN1 or 0 if t < 20 then STATE.on = 1 end if t > 22 then STATE.on = 0 end OUT1 = STATE.on
STATE.min = STATE.min or (IN1 or 0) STATE.max = STATE.max or (IN1 or 0) local v = IN1 or 0 if v < STATE.min then STATE.min = v end if v > STATE.max then STATE.max = v end OUT1 = (STATE.min+STATE.max)/2 -- AVERAGE BETWEEN MIN AND MAX OUT2 = STATE.min -- The minimum value ever measured OUT3 = STATE.max -- The maximum value ever measured
# Read two holding registers and scale the results.
from pymodbus.client.sync import ModbusTcpClient
c = ModbusTcpClient("192.168.1.50", port=502)
c.connect()
raw1 = c.read_holding_registers(300, 1, unit=1).registers[0]
raw2 = c.read_holding_registers(301, 1, unit=1).registers[0]
OUT1 = raw1 / 10.0
OUT2 = raw2 / 10.0
c.close()
# Send IN1 as Text to an MQTT Server
import paho.mqtt.publish as publish
publish.single(
"home/scripting/test",
payload=str(IN1), # send as text
hostname="192.168.1.60",
port=1883,
auth={"username": "mqttuser", "password": "mqttpass"}
OUT1 = 1 # ok
import requests
OUT1 = 0
try:
response = requests.get("https://httpbin.org/json", timeout=5)
OUT1 = response.status_code
response.raise_for_status()
OUT2 = response.json()["slideshow"]["title"]
except Exception as error:
OUT2 = str(error)
- IN1 = weather information as text
- IN2 = expected afternoon temperature (number)
- Output format: Temp: XX°C - DESCRIPTION
- DESCRIPTION must be truncated to 20 characters and end with .. if longer
- Use only plain JavaScript compatible with Jint
- Assign the result to OUT1"
CHANGE LOG
- Separated module for X1 and L1.
- Both modules now support LUA Scripting!
- X1 Module supports Python 2.7 with all basic libraries and paho/mqtt, requests, urllib2, urllib3, pymodbus, schedule, jinja2, flask, websocket, yaml, bacpipes (BacNet!) and much more.
- Completely re-engineerd system for including packages.
- Completely re-engineered separated worker process for Lua and Python scripting.
- Timeout can be 0 (zero), for endless processes like receiving mqtt or a webserver!
- Number of Inputs and Outputs can be 0 – 50 (instead of 1-50), so you can start a webserver or script without any input or output.
- Triggering the Clear function will release the Worker process (handy when using timeout=0)
- Implemented STATE memory (memory within the same block, so you can do: STATE.x = (STATE.x || 0) + 1; OUT1=STATE.x; to create a counter every time you trigger.
- Implemented SHAREDSTATE memory (memory between multiple blocks!), so you can do: SHAREDSTATE.x = 5 in one block and use OUT1=SHAREDSTATE.x in another block.
- Feature: Set script timeout and see Execution time. Test it with a script like: for (i=1;i>0;i++) {let x=5;}
- Fix: Update Notification in GPA (didn't work!).
- Fix: You couldn't Trigger the block when not all inputs are set, fixed by pre-filling with 0 (zero).
- Fix: A lot of small fixes ans possible NullPointerExceptions.
- Feature: Implemented great Debug logging (enable Debug to see what's happening).
- Feature: Debugging shows script execution time. (a hard limit is set at 200ms).
- Initial version
- Tested on Gira GPA v6.0. X1: v3.0.52 and L1: v2.5.149, but may work on lower versions.
More powerfull than ever!
