Is there a problem using Switch Actor for low voltage?
I would not recommend to mix 230V and 24V circuits on one switch actor. At least you have to make absolutely sure that the isolation between the channels is good enough for the application - SELV, presumably.
Once you've used a channel to do high current switching you shouldn't reuse it for switching signal transmitting connections anymore.
But if you beware of that, I see no general problem in switching low voltage applications.
(Of couse you have to take care that mixing non SELV with SELV is allowed by the device if you want to do that)
