Can I use the WireGate as an IP gateway for the HS?
    HS/FS Can I use the WireGate as an IP gateway for the HS?
    Sorry to ask my question in English. maybe this question was already asked before but could not find it in the forum.
    Can I use my (already connected and working) WireGate as an IP gateway for my HomeServer?
    I have 1 HS3 (connected to USB) and I want to test my new HS4, but don't want to buy a second USB-KNX Din module.
    Thanks
    Wouter.
    Hi Wouter
    Yes you can. How is the Wiregate connected to the KNX? If it's connected with the recommended TPUART Gateway everything is fine.
    Everything else: it depends.
    Grüsse Bodo
      Bodo, thanks for answering... one question stays open?
      My Wiregate is connected via the TPUART Gateway, but how should I configure the HS to use the on Wiregate connected TPUART as IP gateway?
      Thanks, Wouter
