Alarm/Keyless-in/SMS integration
    KNX/EIB Alarm/Keyless-in/SMS integration
    Hi.
    Tomorrow I will configure my alarm installation. I will use it together with the Gira door communication system and a SMS gateway (for control and feedback).
    I spent a while thinking on how to connect them all and I think I came with a possible solution. Let me know if I am doing something wrong. I've attached an image so you can better understand.
    Here is what I have:
    -2 Binary inputs modules (230v and contact)
    -SMS Butler for SMS control
    -A regular switch actuator
    -2 gira led signs that will indicate the status of the alarm (armed/disarmed)
    -Gira Keyless in devices that will arm/disarm the alarm
    -Gira KNX alarm central
    What I want:
    -Be able to arm/disarm alarm with keyless in devices
    -Be able to arm/disarm alarm with SMS Butler
    -Be able to arm/disarm alarm with KNX telegrams/objects/software
    -Led sign stays sincronized with alarm state
    -Use as few actuators/inputs as possible
    What I don't know:
    -I will use 2 connections (3 and 4) from the actuator to the led signs (one for green light, other for red light). How can I ensure that only one (green or red) lights up?
    -Simultaneous to the 230v connection to the red led (alarm armed) I also need to feed a 0v contact to the SMS Butler (6) for alarm status. How can I link 2 actuator connections?
    -Can I just link/group the 0v binary input of the keyless in to the Alarm 'arm' object?
    Any help will be appreciated
    Thanks.
