Zitat von nigelg
Zitat von nigelg
The problem is split into 2 parts.
Part 1. The central heating system is producing hot water, based on external temp and return temp. That's it. It's not concerned by the room temp. It's duty is to produce ad-hoc hot water for the consumers.
Part 2. The room thermostat is supposed to control a valve mechanism (EMO or thermic valve) and make sure the desired temp is reached and maintained. This implies having at disposal hot water at sufficient temperature. In my case, there are sensors on the departure and return circuit. There is also a 3 way valve mixing a certain % of return water.
Zitat von nigelg
On the opposite, the temp of water flowing back to the central is almost equal to the departure temp, the system switches the burner Off.
