weinzierl baos 772
    HS/FS weinzierl baos 772
    Hi all
    im having trouble connecting a homeserver to a weinzierl baos 772
    The ip on the baos is 192.168.1.100 ph 1.1.100
    hs is pointed to the 1.1.100 in ip/routing option port 3671,
    multicast 224.0.23.12
    Anyone know what is the problem, or isnt it possible to do this?
    Before we used a schnider ip/router and it work fine.
    /P
    The BAOS supports only KNXnet/IP (tunnel). For the connection of HS to the the bus you will need the KNXnet/IP routing protocol. So you will need a router! The BAOS won't work for this.
    Chris (https://proknx.com)
    wir haben ARAGON entwickelt, einen offline Sprachassistenten für KNX.
    Google, Amazon und Apple hätten das auch gekonnt. Aber sie verdienen eben besser an unseren persönlichen Daten...
