Gira Homeserver Occupancy Simulator issue
    Hi All,
    If this is in the wrong place, admins feel free to move
    I am having problem with the home occupancy simulator starting and working
    It is set as a logic to start when the alarm is set.
    It was working beautifully untill recently and for the life of me i cannot work out why it is no longer working. The only changes made, is the homeserver firmware has been upgraded to 2.8.
    Is this just me that is having this issue?
    Rgds
    Surreall
    What does the debug page say?
      Did you clear the remanent storage?
      And did you read the help text?
      It says (in German):
      Beispiel
      Aufzeichnungsdauer 1 Woche (MO bis SO), 5 Gruppenadressen.
      Der HS/FS muss zunächst eine Woche aufzeichnen, danach kann die Anwesenheitssimulation ausgeführt werden.
      Wird nun nach 9 Tagen (DI) um 15:00 Uhr die Anwesenheitssimulation gestartet (Abspielen),
      so sendet der HS/FS die Telegramme von vor 7 Tagen (DI) um 15:00 Uhr auf den EIB.
      This means, when the period is one week, you must at least wait for one week to get telegrams.
        Thank you for your reply
        We have now appeared to got it working, clearing the memory helped. And a reinstall of the homeserver.
        We have now set it to one day, and has 10 data points in it so far.
        I am still very confused what happened. But at least the memory is recording data. And of course if forgot it doesnt record with the bus monitor running - doh!
        So the plan is to leave it running untill tomorrow, then start it to see if it is replaying the recorded data.
        Regards
        Surreall
        PS thankyou for your help, the clear memory was a damn good idea
