I am going to update an existing heating system in an office building.
The radiator groups are controlled by a 3-way valve with a motor that only has 2 230v control inputs. One is drive open, one is drive-close.
Details here: http://cn.siemens.com/cms/cn/English...QL_EN_4505.pdf
Nouw I want to control it proportional. One way to do it is to use an actor than can drive the motor based on drive time. I.e. valve 50% open is drive 1/2 of the total driving time. Is there a KNX actor that is build for this purpose ? Or can I use a shutter actor with this time function to drive the valve to an absolute value.
Another option, that I like better, is to replace the motor with a 0-10v controlled motor, and then simply use an analog KNX actor with 0-10v outputs.
Any thoughts on this ?
Thnx,
Mike
Thnx,
Mike
