IP Programming errors?
    KNX/EIB IP Programming errors?
    Hi.
    I am having trouble programming 2 Gira KNX devices:
    1 - Gira Smartsensor (1246xxx). When programming it gives me the following error:
    Filename: W:\ECON\Projekte\IOP\IOPEconZielsystemC\Source\Spe icher.cpp
    Line: 693
    Function: TSpeicher:: DownloadUser
    Date/Time: 22.09.12 / 10:37:19
    Caption: destination device
    Error: Error while downloading!
    Error Details:
    I have this error on all my Smartsensors (I have 3 of them).
    I am using ETS3 (3.0f) on Windows XP. I am using a Weinzierl BAOS 770 IP Interface for programming.
    I have searched for this error online and it seems to be related to the IP programming. I do not want to buy
    an RS232 or USB interface just to program this devices. I programmed all other devices in my installation with no problem.
    2 - Gira KNX Alarm System (1142):
    When I try to download to the device I get a "device is not responding" after a while. The device however responds to the "Read info"
    command. I've already tried to program it alone in the bus (only power supply, alarm and programming interface connected) with the same result.
    Any help?
    Thanks.
    Regards,
    Mike
