Cheap window wireless sensor integration into KNX ?
    KNX/EIB Cheap window wireless sensor integration into KNX ?
    Hello
    Does anyone know a cheap way of integrating wireless window opening sensors into KNX?
    I have the following requirements:
    • I need to identify what window is open (for visualisation purposes);
    • Cost should be no more than 20 or 25 Euros per window for a set of 14 windows ( 14 sensors + receiver) ;
    • The wireless receiver could be connected KNX module binary inputs, to USB port of a Raspberry Pi, preferably, or to my LAN ( I'm open to suggestions ...).
    I have a KNXnet/IP gateway.
    I’m searching for references to what window sensor and what wireless receiver I could use.
    Any help could be useful.
    Thanks
    E.Borges
    Maybe you could use enOcean sensors but I don't know if you get a working system with enOcean for 25 Euro for each window (the KNX gateway alone costs between 200 and 300 Euro I guess).
    EDIT: or you can look for FS20 reed contacts like this: http://www.elv.de/2-kanal-tuer-fenst...ttbausatz.html
    Mit freundlichen Grüßen
    Niko Will
