I have a sensor which produces an ON telegram every 1 ltr of waterflow.
How do I get the time between the consecutive ON telegrams?
That way I could calculate the waterflow in liters per minute.
Think I've seen all the available modules but cannot figure out how to do this.
Anyone?
Vielen Dank!
It does work but is not perfect.
Somehow there should also be an output which gives a pulse when the time between pulses is more then for example 60 sec. (<1 liter per minute) and then the module should also be reset and only start counting again after the next received pulse.
That would make such a module perfect for this task!
