I've a problem in the GLE with a simple multiplication.
The data types seem correct, but the output iKO is empty.
I've checked the Debug and see 2 errors, but don't know if they are related to my problem. Any idea, please ?
The first mentioned exception looks more like a string replacement
The second: ?
Obviously this has nothing to do with your problem. Please post screenshot of your logic and the types of the KO's involved.
Are you sure that the logic has already been triggered?
