Im having trouble using hotmail.com for sending e-mails from the homeserver
One problem that i think is that my isp is blocking port 25
Anyone that is using hotmail for sending e-mail that can help me with the settings?
/P
How can you send mails, when you ISP blocks port 25 ??? What about port 465? than you could use smtp with ssl.. or is this not possible with hotmail. In this case I would suggest another mailprovider
if you make something idiot-proof, they start making better idiots......
KNX:3 Linien,121 Teiln.,Siemens N146 und N350E,RasPi mit SV,8 FBH-Kreise mit Siemens HK-Regler,HS4, Haus ohne öffentl. Wasser-/Stromversorg.,PV-Anlage Wechselrichter:SI5048(8kW, 24 Pufferbatterien 1400Ah),PV-Module mit 7,5kWp
