heute ist der Lighty mit Fehler 500 abgestürzt.
Ein einfacher Restart via Webmin hat Abhilfe geschaffen.
Aus dem Log werde ich nicht so richtig schlau
Kann ich da irgend etwas dran beheben, oder ist das so i.O.?
Danke Alex
2012-12-30 14:43:40: (mod_cgi.c.1006) fork failed: Cannot allocate memory
2012-12-30 14:43:40: (mod_cgi.c.747) pipe failed: Too many open files
2012-12-30 14:43:41: (response.c.544) file not found ... or so: Too many open files /cgi-bin/rrdfetch ->
2012-12-30 14:43:42: (response.c.544) file not found ... or so: Too many open files /cgi-bin/rrdfetch ->
2012-12-30 14:43:43: (response.c.544) file not found ... or so: Too many open files /cgi-bin/rrdfetch ->
2012-12-30 14:43:47: (mod_cgi.c.742) pipe failed: Too many open files
2012-12-30 14:43:59: (mod_cgi.c.1006) fork failed: Cannot allocate memory
2012-12-30 14:44:04: (response.c.544) file not found ... or so: Too many open files /cgi-bin/rrdfetch ->
2012-12-30 14:44:10: (response.c.544) file not found ... or so: Too many open files /cgi-bin/rrdfetch ->
2012-12-30 14:44:39: (response.c.544) file not found ... or so: Too many open files /cgi-bin/r ->
2012-12-30 14:45:39: (response.c.544) file not found ... or so: Too many open files /cgi-bin/r ->
2012-12-30 14:46:44: (response.c.544) file not found ... or so: Too many open files /cgi-bin/r ->
2012-12-30 14:47:44: (response.c.544) file not found ... or so: Too many open files /cgi-bin/r ->
2012-12-30 14:48:45: (response.c.544) file not found ... or so: Too many open files /rsslog.php ->
2012-12-30 14:48:46: (response.c.544) file not found ... or so: Too many open files /cgi-bin/rrdfetch ->
2012-12-30 14:48:51: (response.c.544) file not found ... or so: Too many open files /cgi-bin/r ->
2012-12-30 14:48:57: (response.c.544) file not found ... or so: Too many open files /cgi-bin/rrdfetch ->
2012-12-30 14:49:00: (response.c.544) file not found ... or so: Too many open files /cgi-bin/rrdfetch ->
2012-12-30 14:49:03: (response.c.544) file not found ... or so: Too many open files /cgi-bin/rrdfetch ->
2012-12-30 14:49:04: (response.c.544) file not found ... or so: Too many open files /cgi-bin/rrdfetch ->
2012-12-30 14:49:10: (response.c.544) file not found ... or so: Too many open files /cgi-bin/rrdfetch ->
2012-12-30 14:49:16: (response.c.544) file not found ... or so: Too many open files /cgi-bin/rrdfetch ->
2012-12-30 14:49:22: (response.c.544) file not found ... or so: Too many open files /cgi-bin/rrdfetch ->
2012-12-30 14:49:28: (response.c.544) file not found ... or so: Too many open files /cgi-bin/rrdfetch ->
2012-12-30 14:49:31: (response.c.544) file not found ... or so: Too many open files /cgi-bin/rrdfetch ->
2012-12-30 14:49:54: (response.c.544) file not found ... or so: Too many open files /cgi-bin/r ->
2012-12-30 14:50:49: (response.c.544) file not found ... or so: Too many open files /cgi-bin/rrdfetch ->
2012-12-30 14:50:55: (response.c.544) file not found ... or so: Too many open files /cgi-bin/rrdfetch ->
2012-12-30 14:50:59: (response.c.544) file not found ... or so: Too many open files /cgi-bin/r ->
2012-12-30 14:51:59: (response.c.544) file not found ... or so: Too many open files /cgi-bin/r ->
2012-12-30 15:28:04: (mod_indexfile.c.180) file not found ... or so: Too many open files /visu_svn/visu/ -> /var/www/visu_svn/visu/
2012-12-30 15:28:20: (mod_indexfile.c.180) file not found ... or so: Too many open files /visu/ -> /var/www/visu/
2012-12-30 15:28:41: (mod_indexfile.c.180) file not found ... or so: Too many open files /visu_svn/visu/ -> /var/www/visu_svn/visu/
2012-12-30 17:46:31: (mod_indexfile.c.180) file not found ... or so: Too many open files /visu_svn/visu/ -> /var/www/visu_svn/visu/
2012-12-30 19:04:15: (mod_indexfile.c.180) file not found ... or so: Too many open files /visu_svn/visu/ -> /var/www/visu_svn/visu/
2012-12-30 19:04:22: (mod_indexfile.c.180) file not found ... or so: Too many open files /visu_svn/visu/ -> /var/www/visu_svn/visu/
2012-12-30 19:04:25: (mod_indexfile.c.180) file not found ... or so: Too many open files /visu_svn/visu/ -> /var/www/visu_svn/visu/
2012-12-30 19:04:27: (mod_indexfile.c.180) file not found ... or so: Too many open files /visu_svn/visu/ -> /var/www/visu_svn/visu/
2012-12-30 19:04:30: (mod_indexfile.c.180) file not found ... or so: Too many open files / -> /var/www/
2012-12-30 19:05:13: (server.c.1475) server stopped by UID = 0 PID = 32584
2012-12-30 19:05:14: (log.c.75) server started
Danke Alex
