Hi.
I'm starting to program my HomeServer 3.
I've uploaded my first project via the expert software but it doesn't seem to communicate with the KNX bus (at least the quad client doesn't).
I have a Weinzierl BAOS 770 KNX IP device that I already used with Openremote and OpenHab with no problem. I've set EIBNet/IP Routing in the project setting with the correct physical address of the device (the one in ETS) and 224.0.23.12:3671 as the multicast address.
The HS3 seems to somehow connect to the EIB because it throws no error and shows the EIB date on startup.
However... when I use the QuadClient it seems it doesn't act on any switch or doesn't read any value.
What am I doing wrong? How can I check for connectivity inside the QuadClient?
Also... is there anywhere I can get any english HS documentation besides Gira Academy page and the one bundled with the Expert software?
Thanks.
Thanks.
