Gira tastsensor 2plus (1052xx) won't set Temp. properly
    HS/FS Gira tastsensor 2plus (1052xx) won't set Temp. properly
    Hello,
    we have a problem with setting the temperature via the tastsensor and also through gira HS-Client. We use all 3 ports/telegramms - Basic, Setpoint and Actual temperature. In Client program (Visu) we have +/- buttons to increase/decrease the setpoint by 0.1 degC. This information we send to Basic. If we change the setpoint manually on the TS, that's still ok, but the value in Basic does not copy the setpoint. And so we get the problem when we again want to change the temperature through +/- buttons, it continues changing from the value of Basic, which is in this case the former value of setpoint, before any change on the TS was made.
    We also tryied using logic editor in HS-Experte to copy the value in Setpoint into Basic whenever it changes or even use the same group adress for Basic and Setpoint, but the result was inproper function of Tastsensor and cyclical sending telegrams through bus.
    Did anyone of you come over this? If it was already discussed here in forum please redirect me there, because my German was not good enough to find it. Your help would be gladly appreciated!
    Thanks for reading such a long post
    korst
    ahoj
    neviem, ci ta moj priatel po anglicky dobre pochopil.. ak ano: mas skusit vynechat basic telegram.
      Zdravim,
      fakt som necakal ze dostanem odpoved v slovencine no basic telegramom to nebude skusal som to uz a teraz pre istotu znova. teda ak som to spravne pochopil a mal som rovno +/- ikonkami vo Visu nastavovat setpoint. v tom pripade sa neprepisala totiz hodnota v setpointe na tlacitku (tastsensore). nevadi, ako som to totiz este raz vsetko teraz skusal dosiel som na riesenie! spravil som si v logike taky prikaz ktory pri stlaceni +/- ikonky priradi hodnote v basicu aktualnu hodnotu v setpointe +/- 0.1 degC (s vyuzitim internych premennych). takto to konecne funguje ako som chcel. prikladam obrazok s logikou. Dakujem teda, bez vas by som to asi tak skoro nevyriesil :]
      korst
      IN ENGLISH:
      claus-w advised me to avoid using the Basic telegram. I thought it wont work as I was pretty sure I've tried this already. I was right it did not work but by trying all the possibilities again I finally came to an successful solution:
      As the value in Basic did not copy the changes in setpoint made on the tastsensor I've decided to use the +/- buttons to increment (or decrement) the value in setpoint and send it to Basic (command in increment button: Setze "basic, 1/4/13" auf Wert von "temperature buffer +"). That finally works. Thanks claus-w for pushing me into revision of all my tryings again and so finding the solution
      korst
