Experte 4.0 und Python 2.6
    HS/FS Experte 4.0 und Python 2.6
    In previous HS Expert versions I used "homemade" function blocks to convert a Float to a String.
    Had one for 1, 2 and 3 decimals.
    For example 2 decimals:
    5012|0|""|"'%.2f' % EN[1]"|""|1|0|0|0
    With HS Expert version 4 this does not work anymore.
    Maybe because the Python version has changed?
    Now I only see the integer part and no decimals.
    Like 16 in stead of 16,45
    How should the function look like with HS Expert version 4
    Danke.
    Just found out that the function works correct on QC but not on the iPhone and iPad apps....
    In fact, the iPhone app does not work at all anymore.
    It shows the green connection dot but only displays the spinning icon.
    What a crappy (and expensive) piece of software.
