hello,
did anybody tried to integrate HS with Paradox using IP100 module ( Paradox - Headquarters )?
as it sends/receives all zone/partition status/arming/disarming data it might be easy to integrate without dedicated paradox-knx gateway.
regards
Artur
hello,
regards
Artur
sure, tokka gateway would be great solution but;
1. have to pay for Paradox PRT3 communication module to connect TOKKA/KNX
2. have to pay for TOKKA/KNX gateway itself
3. already have IP100 that allows full management/reporting via LAN
that is why I wondered about communication HS <> IP100
does anybody know how should HS->IP telegram look like to query IP100 for let's say partition1 status?
