EIBd auf FritzBox 7170- freetz
    Hallo zusammen
    so hab jetzt freetz drauf auf meiner fb7170
    groupwrite und so machen keine Probleme nur:
    eibd
    root@fritz:/usr/bin# eibd
    Illegal instruction
    root@fritz:/usr/bin# strace -f eibd
    execve("/usr/bin/eibd", ["eibd"], [/* 208 vars */]) = 0
    old_mmap(NULL, 20, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aaad000
    open("/lib/libuClibc++.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
    open("/usr/lib/libuClibc++.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
    open("/usr/lib/freetz/libuClibc++.so.0", O_RDONLY) = 3
    fstat(3, {st_mode=S_IFREG|0755, st_size=151192, ...}) = 0
    old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aaae000
    read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0\20\273\0\0004\0\0\0"..., 4096) = 4096
    old_mmap(NULL, 217088, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aabe000
    old_mmap(0x2aabe000, 141716, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2aabe000
    old_mmap(0x2aaf0000, 10536, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x22000) = 0x2aaf0000
    close(3)                                = 0
    munmap(0x2aaae000, 4096)                = 0
    open("/lib/libc.so.0", O_RDONLY)        = 3
    fstat(3, {st_mode=S_IFREG|0644, st_size=410640, ...}) = 0
    read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0\340\253\0\0004\0\0\0"..., 4096) = 4096
    old_mmap(NULL, 499712, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aaf3000
    old_mmap(0x2aaf3000, 404576, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2aaf3000
    old_mmap(0x2ab65000, 8244, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x62000) = 0x2ab65000
    old_mmap(0x2ab68000, 18768, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2ab68000
    close(3)                                = 0
    open("/lib/libgcc_s.so.1", O_RDONLY)    = 3
    fstat(3, {st_mode=S_IFREG|0755, st_size=55536, ...}) = 0
    read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0p\32\0\0004\0\0\0"..., 4096) = 4096
    old_mmap(NULL, 122880, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2ab6d000
    old_mmap(0x2ab6d000, 53884, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2ab6d000
    old_mmap(0x2ab8a000, 1008, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xd000) = 0x2ab8a000
    close(3)                                = 0
    open("/usr/lib/freetz/libc.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
    close(3)                                = 0
    open("/usr/lib/freetz/libgcc_s.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
    close(3)                                = 0
    close(3)                                = 0
    stat("/lib/ld-uClibc.so.0", {st_mode=S_IFREG|0755, st_size=21532, ...}) = 0
    mprotect(0x2ab65000, 4096, PROT_READ)   = 0
    mprotect(0x2aabc000, 4096, PROT_READ)   = 0
    ioctl(0, TIOCNXCL, {B38400 opost isig icanon echo ...}) = 0
    ioctl(1, TIOCNXCL, {B38400 opost isig icanon echo ...}) = 0
    brk(0)                                  = 0x474000
    brk(0x475000)                           = 0x475000
    --- {si_signo=SIGILL, si_code=SI_KERNEL, si_addr=0} (Illegal instruction) ---
    +++ killed by SIGILL +++
    Illegal instruction
    Und bei ldd:
    root@fritz:/usr/bin# ldd eibd
            libuClibc++.so.0 => not found
            libc.so.0 => /lib/libc.so.0 (0x2aabe000)
            libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x2ab38000)
            ld-uClibc.so.0 => /lib/ld-uClibc.so.0 (0x2aaa8000)
    danke im vorraus
    ich bin gerade am verzweifeln. Ich habe das gleiche Problem.
    Haben Sie eibd auf der 7170 zum laufen bekommen?
    Ich bin jetzt am ende und weis nicht mehr weiter was hier fehlen soll.
    Bitte um kurze Rückmeldung.
    Vielen dank im Voraus
