Overwrite a lock
    Overwrite a lock
    I have a presence detector #1 (Merten Argus 220 new model) which should only be working when a binary input value is equal to 1 (the binary input value is an indicator if the home alarm is on or off). I have a secondary detector #2 (Merten Argus 220 old model) that should overwrite the binary input value.
    In other words ... when the home alarm is on (binary input value = 1), the presence detector #1 should be working and detecting any presence. When the presence detector #2 detects any presence, the presence detector #1 should NOT be working (even if the home alarm is on) for 30 minutes.
    I was thinking of using the lock object of presence detector #1 to accomplish this, but I'm stuck.
    Can you recommend how I can set this? If necessary I can also use an eibpc to accomplish this, but I would prefer to accomplish this without eibpc.
    Tx for your help -- Ivan
    Hi Ivan,
    I suppose that you intend to use just one group address for armed signal, activated sensor #2 and lock function of sensor #1 when you are talking about "overwriting" the lock function. This will not work as the last occurred signal will always overwrite the lock function.
    You will need a AND logic with two inputs:
    1) the "armed" signal of your home alarm and
    2) the active indicator of sensor #2
    Output would be then the lock function of sensor #1.
    Now you have to take care of the polarity of the signals.
    Home alarm armed = 1
    Sensor #2 not active = 1
    AND output = 1 -> unlock sensor #1
    I haven't tested it but it should work.
    Cheers
    Christian
    Chris (https://proknx.com)
    wir haben ARAGON entwickelt, einen offline Sprachassistenten für KNX.
    Google, Amazon und Apple hätten das auch gekonnt. Aber sie verdienen eben besser an unseren persönlichen Daten...
      Tx for your reply. I'll create the logical functions in eibpc.
