Combine on-delay function with immediately on function
    I have a Merten actuator 648490 (old model) which I've programmed with an on delay. When I'm sending a message to the actuator, the channel is switched on after a delay of eg 5 minutes.
    Can I combine this function with an immediately on function? So when another message is sent to the actuator, the channel is switched on immediately, without the delay of eg 5 minutes.
    How should I accomplish this?
    Ivan
