Gira Smartsensor
    KNX/EIB Gira Smartsensor
    Hi.
    I have 3 Gira smartsensors installed through the house.
    I've programmed all of them with the basics but I wanted to fine tune some of the functions.
    If someone can help with these, I would be most grateful:
    1. - I would like the sensor to activate/light up when there is presence in the room. For that purpose I have set the 'background illumination via object' to true and linked it to the presence detector. However, when someone enters the room the smartsensor activates the background illumination ONLY which is quite stupid. I am presented with a blank, lit up screen. I still have to touch it to display any info. How can I do what I wanted?
    2. - How can I display on the main screen the smartsensor's internal temperature probe reading? I tried linking a line to the smartsensor's temperature object without success. I probably can't link an object to another in the same device, can I?
    3. - How can I use the smartsensor's internal messaging system? I would like to be able to send it some info (either with openremote or HS) like phonecalls or something.
    Thanks.
    Regards,
    Mike
