Camera plugin and XP embedded
    Q-Client Camera plugin and XP embedded
    Since I updated to 4.0, my camera plugin have stopped working on my QC running on XP embedded. I don't even get the "second line" where you select cameras, and image is just black.
    It worked fine on this screen before upgrade to 4.0 (was 2.8) and it still works with my other QC screens (where OS is W7 or "standard" XP). could it be a problem with XPe (only thing I can imagine) or do You have any other suggestions?
    Camera archive is still working fine.
    I found a solution, I imported the older plugin (from Experte 2.8, it had version number 1.1-something), and then it started working again. Does anyone know if it is ok to do so or will I get worse problems later on?
    /U
