HS Web Pages/IP Devices analyse ....</td><td>....
    Hello,
    I'm writing a module to analyse the HS Login list and extract non-local visitors, afterall, it's a web page like any other.
    Impossible to make this thing work.
    After much trouble, I use the DaCom "Text Splitter", and now I realize that the HS server does mess-up when it sees the sequence
    ....</td><td>....
    The Login list is a table, hence it is full of these sequences.
    To verify this scenario:
    use the DaCom module
    fill a static variable as in the DaCom example
    Das#ist#ein#Text Trenner=35 Pos=2 output="ein" Number=4
    same exercice with
    Das<ist<ein<Text Trenner=60 Pos=2 output="ein" Number=4
    same exercice with
    <td>Das</td><td>ist</td><td>ein</td><td>Text</td>
    NO GO although the Number=9 which is correct, but no output
    Is this supposed to work ? If it doesn't, it's useless in many cases.
    Thanks
    Raymond
    ....</td><td>....
    Answering my own question:
    write a module to get rid of the extraneous html code.
    I consider this as a workaround, the HS shouldn't mess-up with the html code.
    No one has an idea ?
    Greetings
    Raymond
      Raymond,
      unfortunately I do not understand what your problem is exactly.
      Please load up a LIB with your website-query, logic and the Visu-page, so that I / we can have a look on it.
      Gruss aus Radevormwald
      Michel
        With pleasure, but, ..... humm, I don't know how to do it
        Raymond
          Eventually, you could do a simple check.
          Select "Communication, Web Pages/IP Devices, do an analyze on your HomeServer Login List. Try to get something in a 14Byte var. Does it work ? In my case: no.
          Feed the Login List to a logic module that removes all <td></td> pair. Re-do the previous test, now I can get something in a 14Byte var.
          I would love if someone can confirm/deny my statement. It is very possible that there is something dead wrong with my installation, a setting very obvious that all of you know, except me.
          Best regards
            ouups, forgot to attach the hsl file
              You may have an error in your logic module!
              Have a look on the definition of output 1! It is not initialized with '' for text data.
              5004|1|0|0|1|1 # Output 1
              ---> 5004|1|""|0|1|1 # Output 1
              Michel
                It is worse than that, I misunderstood the word "initial value", but by re-reading "HS2-Doku-Logiksprache.pdf" it's OK
                Those newbies are really a pain
                btw, the module was working despite the error
