HS Web Pages/IP Devices analyse .
    Hello,
    Sorry to be a pain
    I'm unable to extract data from an RSS feed, if the data is inside the
    <![CDATA[ tags.
    I undestand that the XML parser doesn't interpret the data inside those
    tags, but I find it abnormal that the HomeServer is unable to catch the
    data.
    NB: all other extract work fine. (I've just finished a web extract for Météo with over 310 data blocks, no prob).
    Maybe my procedure is wrong, but I've tested this several times, same result.
    NB: many weather forecast RSS feed use those <![CDATA[
    Thank you for your help
    Raymond
    Hi Raymond,
    for the RSS-feed of www.formel1.de, I am using the settings you'll find in the attached screenshot. Beside the German Umlaute, which I've ignored until now, it works ok.
    Hope that helps.
    Bye,
    Harald
      Thank you, I'll try
      But you could use the Matthias's logic module to solve it.
      I've written a similar module to cope with the Unicode UTF-8 (Google sites, like the french EIB forum) and the french character set.
      Thanks
      Raymond
        No, I'm not getting anything out of CDATA.
        All other variables (title, subtitle etc) are OK, so I guess the syntax of the parsing is OK (otherwise, nothing is displayed).
        Maybe something else ? not seen in your example ?
        NB: In my case, the whole forecast is put into a single CDATA, maybe it is too big ? I seem to remember that a 14Byte var could hold up to a practical limit of 64K, is that correct ?
        Greetings from a warm Midi-Pyrénées
        Raymond
          No, not 64k, but only 10000 bytes.
          Gruß Matthias
          - PN nur für PERSÖNLICHES!
            Thank you.
            I think it will fit. 10K is a huge amount of text.
            Maybe version dependent ? my version of the Experte is 2.1.2.061109
            Best regards
            Raymond
              Well, yet another bobo with ther web site analyze.
              After double checking the syntax, I didn't find/see any error.
              So I send the data captured from CDATA to a logic module which removes all of the html code and .... all of a sudden, it works.
              Very bizarre, there was already that thing with </td><td>, now it goes about </p><p>, </b><b>, <br /> etc don't know which one is the cause, I removed everything.
              NB: the size of the 14Byte var is 6K, so far below the 10K limit, just in case you think that removing some text reduces the size to just below 10K .
              Greetings
              Raymond
