URGENT: Problem with TK Gateway and Gira House Station
    Hello,
    I have 1 Gira door station, 1 Gira house station, and 1 Gira TK Gateway.
    When I make a call from the door station, the house station ring just one time, then I can't take call from the house station, and only the phone ring and I can take call from phone.
    I found the problem, but I don't know how to resolve it.
    On the Gira TK Gateway, in Telefonbuch ==> Telefonbucheintrag:
    I have the option: Anrufbeantworter
    When this option is Enabled:
    When i make a call, i can only answer from the phone
    When this option is Disabled:
    When i make a call, i can answer from the house station and from the phone, but I need to use the "0" to answer from the phone
    Do you have a solution to take the call from Gira House Station, and from a phone without pressing the "0" to take the call?
    Thank you and have a nice day..
    UP Please?
    Thank you
      Its not possible to use the "Anrufbeantworter"-function and house stations at the same time. The gateway doesn´t recognize if you take the call, it switches at the time you are pressing "0", then the door stations will quiet.
      If "Anrufbeantworter" is activated, it connects immediality to the phone line, because a answering machine can´t press "0".
