Hi.
I want to integrate my HS3 with Eventghost. I have all the RS232 and IR hardware already configured in Eventghost so... it would really help me a lot.
I've added the broadcaster plugin in EG to receive UDP packets.
I've activated in HS expert the communication object gateway (in project-->project settings-->network) and entered the same port as in EG. I've also added the EG's IP address and subnet in Sender1 field.
Nothing happens.
In the communications section of HS expert there is also an IP/EIB Telegrams (sending) section. I've created a sample telegram....but don't know how to set it up.
Any help?
I need to both send and receive IP telegrams in HS. How can I do this?
Thanks in advance.
Regards,
Mike
Nothing happens.
Any help?
Thanks in advance.
Regards,
Mike
