Gira tastsensor 3 - Led problem
    I'm sorry if this problem was allready posted/solved on this forum, but my german is not that good...
    My problem:
    I have multiple tastsensor 3 buttons in our home, wich I programmed like they should. Now after some time, some leds are active wich shouldn't be. I tried reprogramming the tastsensor, but the led in question keeps on.
    Even is the tastsensor goes in to alarm mode (all leds blink red) the blue led keeps on also, wich isn't supposed to be the case..
    I conctacted the store wich sold me the complete setup for our home, but instead of giving a solution or an explanation why this is happening, they just switch out the tastsensor, for free luckily, but I don't know if there going to be keep doing this after a couple of years...
    Has anyone had this same problem? Is there a way to completely "reset" a tastsensor? I allready tried resetting it trough ETS
    If it's not clear what the problem is exactly, I can post a picture...
    This is a known issue. Gira now has changed the LED. Go to your dealer and get them changed into the new revision I05.
    https://knx-user-forum.de/knx-eib-fo...r-3-immer.html
      Oh, thank you for the quick reply. Is there any way to check when I get a replacement tastsensor, to see if this is indeed the improved version? On the package itself or at the back of the button?
      Thanks!
        There is a label on the device itself.
          Ok, I will take them to the shop were I bought them.
          Again, thank you for the quick reply's
