Gira Homeserver Logik
    Weiß jemand wie ich eine phython script vom homesever ausführen kann?
    Meines Wissens nicht direkt was willst du den genau machen?
      Geht schon: in einen Logikbaustein packen.
        Sollte nur den samsung tv auf stumm schalten wenn jemand klingel!
        den code werde !
        import socket
        import base64
        import time, datetime
        import argparse
        from argparse import ArgumentParser
        parser = ArgumentParser()
        # Add more options if you like
        parser.add_argument("-key", "--key", dest="key",
        help="write report to FILE", metavar="FILE")
        parser.add_argument("-myip", "--myip", dest="myip",
        parser.add_argument("-tv", "--tv", dest="tvip",
        parser.add_argument("-mc", "--mc", dest="mymac",
        parser.add_argument("-q", "--quiet",
        action="store_false", dest="verbose", default=True,
        help="don't print status messages to stdout")
        args = parser.parse_args()
        print(args.key)
        tvip = '192.168.0.99'
        myip = '192.168.0.7'
        mymac = 'xxxxxxx'
        #What the iPhone app reports
        appstring = "iphone..iapp.samsung"
        #Might need changing to match your TV type
        tvappstring = "iphone.UE55C8000.iapp.samsung"
        #What gets reported when it asks for permission
        remotename = "Python Samsung Remote"
        # Function to send keys
        def sendKey(skey, dataSock, appstring):
        messagepart3 = chr(0x00) + chr(0x00) + chr(0x00) + chr(len(
        base64.b64encode(skey))) + chr(0x00) + base64.b64encode(skey);
        part3 = chr(0x00) + chr(len(appstring)) + chr(0x00) \
        + appstring + chr(len(messagepart3)) + chr(0x00) + messagepart3
        dataSock.send(part3);
        # Open Socket
        sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
        sock.connect((tvip, 55000))
        # First configure the connection
        ipencoded = base64.b64encode(myip)
        macencoded = base64.b64encode(mymac)
        messagepart1 = chr(0x64) + chr(0x00) + chr(len(ipencoded)) \
        + chr(0x00) + ipencoded + chr(len(macencoded)) + chr(0x00) \
        + macencoded + chr(len(base64.b64encode(remotename))) + chr(0x00) \
        + base64.b64encode(remotename)
        part1 = chr(0x00) + chr(len(appstring)) + chr(0x00) + appstring \
        + chr(len(messagepart1)) + chr(0x00) + messagepart1
        sock.send(part1)
        messagepart2 = chr(0xc8) + chr(0x00)
        part2 = chr(0x00) + chr(len(appstring)) + chr(0x00) + appstring \
        + chr(len(messagepart2)) + chr(0x00) + messagepart2
        sock.send(part2)
        sendKey('KEY_MUTE',sock,tvappstring)
        sock.close()
        wenn jemand mir so eine logik machen könnte?
        Danke
          Warum nimmst du nicht den fertigen Baustein 11881 von Knet? Zu finden hier im Downloadbereich??
          Gruß Thorsten
            Weil die Funktion Mute nur mit der registrierten Version funktioniert!
              Wie wäre es mit registrieren?!
                @mathias
                Kannst du mal verraten , wir man Python integrieren kann. Interessiert mich auch brennnd
                Gesendet von meinem iPhone mit Tapatalk
                  https://github.com/knxuf
                    Ich verstehe glaube es einfach nicht!!
                      Wo ist den der fehler bei der logik?
                      # -*- coding: iso8859-1 -*-
                      ## Logik-Generator V1.5
                      ## Copyright © 2012, knx-user-forum e.V, All rights reserved.
                      ## This program is free software; you can redistribute it and/or modify it under the terms
                      ## of the GNU General Public License as published by the Free Software Foundation; either
                      ## version 3 of the License, or (at your option) any later version.
                      ## This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY;
                      ## without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
                      ## See the GNU General Public License for more details.
                      ## You should have received a copy of the GNU General Public License along with this program;
                      ## if not, see <http://www.gnu.de/documents/gpl-3.0.de.html>.
                      ### USAGE: python.exe LogikGenerator.py [--debug --en1=34 --en2="TEST"]
                      import sys
                      import codecs
                      import os
                      import base64
                      import marshal
                      import re
                      try:
                      from hashlib import md5
                      except ImportError:
                      import md5 as md5old
                      md5 = lambda x='': md5old.md5(x)
                      import inspect
                      import time
                      import socket
                      import tempfile
                      import zlib
                      import zipfile
                      ### Config ###
                      ## Name der Logik
                      LOGIKNAME="samsung"
                      ## Logik ID
                      LOGIKID="999999"
                      ## Ordner im GLE
                      LOGIKCAT="michael"
                      ## Beschreibung
                      LOGIKDESC="""
                      Samsung tv
                      VERSION="V1.001"
                      ## Bedingung wann die kompilierte Zeile ausgeführt werden soll
                      BEDINGUNG="EN[1] or EN[2] or EN[3] or EI"
                      ## Formel die in den Zeitspeicher geschrieben werden soll
                      ZEITFORMEL=""
                      ## Nummer des zu verwenden Zeitspeichers
                      ZEITSPEICHER="0"
                      ## AUF True setzen um Binären Code zu erstellen
                      doByteCode=False
                      #doByteCode=True
                      ## Base64Code über SN[x] cachen
                      doCache=False
                      ## Doku erstellen Ja/Nein
                      doDoku=True
                      debug=False
                      livedebug=False
                      showList=False
                      ########## Logik ############
                      LOGIK = '''# -*- coding: iso8859-1 -*-
                      ## '''+ LOGIKNAME +''' ### '''+VERSION+'''
                      ## erstellt am: '''+time.strftime("%Y-%m-%d %H:%M")+'''
                      ## Copyright © '''+ time.strftime("%Y") + ''', knx-user-forum e.V, All rights reserved.
                      ## Dieses Werk ist unter einem Creative Commons Namensnennung-Weitergabe unter gleichen Bedingungen 3.0 Deutschland Lizenzvertrag lizenziert.
                      ## Um die Lizenz anzusehen, gehen Sie bitte zu Creative Commons ? Namensnennung - Weitergabe unter gleichen Bedingungen 3.0 Deutschland ? CC BY-SA 3.0 DE
                      ## oder schicken Sie einen Brief an Creative Commons, 171 Second Street, Suite 300, San Francisco, California 94105, USA.
                      ## -- ''' +re.sub("\n","\n## -- ",LOGIKDESC)+ '''
                      #5000|"Text"|Remanent(1/0)|Anz.Eingänge|.n.|Anzahl Ausgänge|.n.|.n.
                      #5001|Anzahl Eingänge|Ausgänge|Offset|Speicher|Berechnung bei Start
                      #5002|Index Eingang|Default Wert|0=numerisch 1=alphanummerisch
                      #5003|Speicher|Initwert|Remanent
                      #5004|ausgang|Initwert|runden binär (0/1)|typ (1-send/2-sbc)|0=numerisch 1=alphanummerisch
                      ##5012|abbruch bei bed. (0/1)|bedingung|formel|zeit|pin-ausgang|pin-offset|pin-speicher|pin-neg.ausgang
                      5000|"'''+LOGIKCAT+'''\\'''+LOGIKNAME+'''_'''+VERS ION+'''"|0|5|"E1 IP TV"|"E2 IP HS"|"E3 MUTE"|"E4 1"|"E3 2"|2|"A1 Daten"|"A2 SystemLog"
                      5001|5|2|0|1|1
                      # EN[x]
                      5002|1|"1"|1 #* IP TV
                      5002|2|"1"|1 #* IP HS
                      5002|3|"0"|0 #* MUTE
                      5002|4|"0"|0 #* 1
                      5002|5|"0"|0 #* 2
                      # Speicher
                      5003|1||0 #* logic
                      # Ausgänge
                      5004|1|""|0|1|1 #* Daten
                      5004|2|""|0|1|1 #* SystemLog
                      #### Python Code ####
                      code=[]
                      code.append([0,"EI",r"""
                      ## KNXUF_XMLScrollList
                      if EI==1:
                      import zlib
                      class KNXUF_XMLScrollList:
                      def __init__(self,localvars):
                      EN = localvars['EN']
                      self.__Version__ = '""" +VERSION+ """'
                      self.__curPos = 0
                      self.__numoutputs = EN[2]
                      self.__lastUsed = 0
                      self.__List = []
                      self.DirectConnect = [ [ [] ] ,0 ]
                      self.EmptyLine = ""
                      self.triggerRegex = [False,False]
                      self.showRegex = False
                      import socket
                      import base64
                      import argparse
                      parser.add_argument('-key', '--key', dest='key',
                      parser.add_argument('-myip', '--myip', dest='myip',
                      parser.add_argument('-tv', '--tv', dest='tvip',
                      parser.add_argument('-mc', '--mc', dest='mymac',
                      parser.add_argument('-q', '--quiet',
                      #args = parser.parse_args()
                      mymac = '00:0A:B3:02:29:FB'
                      print('senden dfdfdfd')
                      appstring = 'iphone..iapp.samsung'
                      tvappstring = 'iphone.UE55C8000.iapp.samsung'
                      def sendKey(self,skey, dataSock, appstring):
                      # Open Socket
                      sock.send(part1)
                      sock.send(part2)
                      #sendKey(self,'KEY_MUTE',sock,tvappstring)
                      sock.close()
                      dbgcode="""
                      postlogik=[0,"","""
                      ## Klasse definieren
                      5012|0|"EI"|"KNXUF_XMLScrollList(locals())"|""|0|0 |1|0
                      5012|0|"(EI or OC[1] or EC[1]) and len(EN[2])>0"|"SN[1].sendKey(self,"KEY_MUTE",sock,tvappstring)"|""|0|0 |0|0
                      ############## Interne Funktionen #################
                      LGVersion="1.5"
                      livehost=""
                      liveport=0
                      doSend=False
                      noexec=False
                      nosource=False
                      doZip=False
                      for option in sys.argv:
                      if option.find("--new")==0:
                      try:
                      LOGIKID=int(option.split("=")[1].split(":")[0])
                      LOGIKNAME=option.split("=")[1].split(":")[1]
                      try:
                      LOGIKCAT=option.split("=")[1].split(":")[2]
                      except:
                      pass
                      except:
                      print "--new=id:name[:cat]"
                      raise
                      sys.exit(1)
                      if LOGIKID >99999 or LOGIKID == 0:
                      print "invalid Logik-ID"
                      sys.exit(1)
                      if LOGIKID <10000:
                      LOGIKID+=10000
                      LOGIKID="%05d" % LOGIKID
                      f=open(inspect.currentframe().f_code.co_filename,' r')
                      data=""
                      while True:
                      line = f.readline()
                      if line.find("LOGIKID=") == 0:
                      line = "LOGIKID=\""+LOGIKID+"\"\n"
                      if line.find("LOGIKNAME=") == 0:
                      line = "LOGIKNAME=\""+LOGIKNAME+"\"\n"
                      if line.find("LOGIKCAT=") == 0:
                      line = "LOGIKCAT=\""+LOGIKCAT+"\"\n"
                      data += line
                      if not line:
                      break
                      f.close()
                      open(str(LOGIKID)+"_"+LOGIKNAME+".py",'w').write(d ata)
                      sys.exit(0)
                      if option=="--list":
                      showList=True
                      if option=="--debug":
                      debug=True
                      if option=="--noexec":
                      noexec=True
                      if option=="--nosource":
                      nosource=True
                      if option=="--zip":
                      doZip=True
                      if option=="--nocache":
                      doCache=False
                      if option.find("--live")==0:
                      livedebug=True
                      debug=True
                      doByteCode=False
                      doCache=True
                      try:
                      livehost=option.split("=")[1].split(":")[0]
                      liveport=int(option.split("=")[1].split(":")[1])
                      except:
                      print "--live=hostort"
                      if option.find("--send")==0:
                      doSend=True
                      try:
                      except:
                      print "--send=hostort"
                      print "HOST: "+livehost+" Port:" +str(liveport)
                      ### DEBUG ####
                      EI=True
                      EA=[]
                      EC=[]
                      EN=[]
                      SA=[]
                      SC=[]
                      SN=[]
                      AA=[]
                      AC=[]
                      AN=[]
                      OC=[]
                      ON=[]
                      if debug or doSend:
                      EA.append(0)
                      EC.append(False)
                      EN.append(0)
                      AA.append(0)
                      AC.append(False)
                      AN.append(0)
                      SA.append(0)
                      SC.append(False)
                      SN.append(0)
                      ON.append(0)
                      OC.append(False)
                      ## Initialisieren ##
                      for logikLine in LOGIK.split("\n"):
                      if logikLine.find("5001") == 0:
                      for i in (range(0,int(logikLine.split("|")[3]))):
                      ON.append(0)
                      OC.append(False)
                      if logikLine.find("5002") == 0:
                      EN.append(logikLine.split("|")[2].replace('\x22',''))
                      EA.append(logikLine.split("|")[2])
                      EC.append(False)
                      if logikLine.find("5003") == 0:
                      if logikLine.split("|")[3][0] == "1":
                      SN.append(re.sub('"','',logikLine.split("|")[2]))
                      else:
                      try:
                      SN.append(int(logikLine.split("|")[2]))
                      except:
                      pass
                      SN.append(logikLine.split("|")[2])
                      SA.append(logikLine.split("|")[2])
                      SC.append(False)
                      if logikLine.find("5004") == 0:
                      AN.append(logikLine.split("|")[2])
                      AA.append(logikLine.split("|")[2])
                      AC.append(False)
                      def bool2Name(b):
                      if int(b)==1:
                      return "Ja"
                      else:
                      return "Nein"
                      def sbc2Name(b):
                      if int(b)==1:
                      return "Send"
                      else:
                      return "Send By Change"
                      def addInputDoku(num,init,desc):
                      return '<tr><td class="log_e1">Eingang '+str(num)+'</td><td class="log_e2">'+str(init)+'</td><td class="log_e3">'+str(desc)+'</td></tr>\n'
                      def addOutputDoku(num,sbc,init,desc):
                      return '<tr><td class="log_a1">Ausgang '+str(num)+' ('+sbc2Name(sbc)+')</td><td class="log_a2">'+str(init)+'</td><td class="log_a3">'+str(desc)+'</td></tr>\n'
                      LOGIKINHTM=""
                      LOGIKOUTHTM=""
                      i=0
                      LEXPDEFINELINE=LHSDEFINELINE=LINDEFINELINE=LSPDEFI NELINE=LOUTDEFINELINE=0
                      if logikLine.find("5000") == 0:
                      LEXPDEFINELINE=i
                      LOGIKREMANT=bool2Name(logikLine.split("|")[2])
                      LOGIKDEF=logikLine
                      LHSDEFINELINE=i
                      ANZIN=int(logikLine.split("|")[1])
                      ANZOUT=int(logikLine.split("|")[2])
                      ANZSP=int(logikLine.split("|")[4])
                      CALCSTARTBOOL=logikLine.split("|")[5]
                      CALCSTART=bool2Name(CALCSTARTBOOL)
                      LINDEFINELINE=i
                      desc=re.sub('"','',LOGIKDEF.split("|")[3+int(logikLine.split("|")[1])])
                      if logikLine.find("#*") >0:
                      desc=logikLine.split("#*")[1]
                      LOGIKINHTM+=addInputDoku(logikLine.split("|")[1],logikLine.split("|")[2],desc)
                      if logikLine.find("5003") == 0 or logikLine.find("# Speicher") == 0:
                      LSPDEFINELINE=i
                      LOUTDEFINELINE=i
                      desc=re.sub('"','',LOGIKDEF.split("|")[(4+ANZIN+int(logikLine.split("|")[1]))])
                      LOGIKOUTHTM+=addOutputDoku(logikLine.split("|")[1],logikLine.split("|")[4],logikLine.split("|")[2],desc)
                      i=i+1
                      if livedebug:
                      EC.append(0)
                      EN.append("")
                      sendVars=""
                      if option.find("--sa") == 0:
                      SA[int(option[4ption.find("=")])]=option.split("=")[1]
                      sendVars+="SA["+str(int(option[4ption.find("=")]))+"]="+option.split("=")[1]+"\n"
                      if option.find("--sn") == 0:
                      SN[int(option[4ption.find("=")])]=option.split("=")[1]
                      SC[int(option[4ption.find("=")])]=True
                      sendVars+="SN["+str(int(option[4ption.find("=")]))+"]="+option.split("=")[1]+"\n"
                      sendVars+="SC["+str(int(option[4ption.find("=")]))+"]=1\n"
                      if option.find("--aa") == 0:
                      AA[int(option[4ption.find("=")])]=option.split("=")[1]
                      sendVars+="AA["+str(int(option[4ption.find("=")]))+"]="+option.split("=")[1]+"\n"
                      if option.find("--an") == 0:
                      AN[int(option[4ption.find("=")])]=option.split("=")[1]
                      AC[int(option[4ption.find("=")])]=True
                      sendVars+="AN["+str(int(option[4ption.find("=")]))+"]="+option.split("=")[1:]+"\n"
                      sendVars+="AC["+str(int(option[4ption.find("=")]))+"]=1\n"
                      if option.find("--ea") == 0:
                      EA[int(option[4ption.find("=")])]=option.split("=")[1]
                      sendVars+="EA["+str(int(option[4ption.find("=")]))+"]="+option.split("=")[1:]+"\n"
                      if option.find("--en") == 0:
                      EN[int(option[4ption.find("=")])]="".join(option.split("=",1)[1])
                      EC[int(option[4ption.find("=")])]=True
                      sendVars+="EN["+str(int(option[4ption.find("=")]))+"]="+"".join(option.split("=")[1:])+"\n"
                      sendVars+="EC["+str(int(option[4ption.find("=")]))+"]=1\n"
                      if option.find("--ec") == 0:
                      # EC[int(option[4ption.find("=")])]=int(option.split("=")[1])
                      sendVars+="EC["+str(int(option[4ption.find("=")]))+"]="+option.split("=")[1]+"\n"
                      print sendVars
                      if option.find("--sc") == 0:
                      sendVars+="SC["+str(int(option[4ption.find("=")]))+"]="+option.split("=")[1]+"\n"
                      print sendVars
                      if option.find("--on") == 0:
                      ON[int(option[4ption.find("=")])]=option.split("=")[1]
                      sendVars+="ON["+str(int(option[4ption.find("=")]))+"]="+option.split("=")[1]+"\n"
                      if option.find("--oc") == 0:
                      OC[int(option[4ption.find("=")])]=True
                      sendVars+="OC["+str(int(option[4ption.find("=")]))+"]=1\n"
                      if option.find("--ei") == 0:
                      EI=(int(option.split("=")[1])==1)
                      sendVars+="EI=1\n"
                      if option.find("--run") == 0:
                      sendVars+="eval(SN["+str(ANZSP+1)+"])\n"
                      def symbolize(LOGIK,code):
                      symbols = {}
                      for i in re.findall(r"(?m)^500([234])[|]([0-9]{1,}).*[@][@](.*)\s", LOGIK):
                      varName=((i[0]=='2') and 'E') or ((i[0]=='3') and 'S') or ((i[0]=='4') and 'A')
                      isunique=True
                      try:
                      type(symbols[i[2]])
                      sym=i[2]
                      isunique=False
                      except KeyError:
                      pass
                      ## überprüft auch die alternativen Varianten
                      if re.match("[ACN]",i[2][-1:]):
                      try:
                      type(symbols[i[2][:-1]])
                      sym=i[2][:-1]
                      isunique=False
                      except KeyError:
                      pass
                      if isunique:
                      symbols[i[2]]=[varName,"["+i[1]+"]"]
                      else:
                      print "Variablen Kollision :" +repr(i[2])+" ist in " +repr(symbols[sym]) + " und "+ varName +"["+i[1]+"] vergeben"
                      sys.exit(1)
                      ## Symbole wieder entfernen
                      LOGIK=re.sub("[@][@]\w+", "",LOGIK)
                      #im Code tauschen
                      for i in symbols.keys():
                      code=[code[0],re.sub("[\@][\@]"+i+"([ACN])",symbols[i][0]+"\\1"+symbols[i][1],code[1]),re.sub("[\@][\@]"+i+"([ACN])",symbols[i][0]+"\\1"+symbols[i][1],code[2])]
                      code=[code[0],re.sub("[\@][\@]"+i+"",symbols[i][0]+"N"+symbols[i][1],code[1]),re.sub("[\@][\@]"+i+"",symbols[i][0]+"N"+symbols[i][1],code[2])]
                      return LOGIK,code
                      NCODE=[]
                      commentcode=[]
                      for codepart in code:
                      NLOGIK,codepart=symbolize(LOGIK,codepart)
                      NCODE.append(codepart)
                      if codepart[0]==0 or codepart[0]==3:
                      commentcode.append("##########################\n## #### Quelltext: ########\n##########################"+"\n##".join( codepart[2].split("\n"))+"\n")
                      #else:
                      # commentcode.append("#"+codepart[2].split("\n")[1]+"\n################################\n## Quelltext nicht Öffentlich ##\n################################")
                      NLOGIK,postlogik = symbolize(LOGIK,postlogik)
                      LOGIK=NLOGIK
                      code=NCODE
                      ## Doku
                      doku = """
                      <html>
                      <head><title></title></head>
                      <link rel="stylesheet" href="style.css" type="text/css">
                      <body><div class="titel">"""+LOGIKNAME+"""</div>
                      <div class="nav"><A HREF="index.html">Hilfe</A> / <A HREF="logic.html">Logik</A> / """+LOGIKNAME+""" / <A HREF="#anker1">Eing&auml;nge</A> / <A HREF="#anker2">Ausg&auml;nge</A></div><div class="field0">Funktion</div>
                      <div class="field1">"""+re.sub("\r\n|\n","<br>",LOGIKDE SC.decode("iso-8859-1").encode("ascii","xmlcharrefreplace") )+"""</div>
                      <div class="field0">Eing&#228;nge</div>
                      <a name="anker1" /><table border="1" width="612" class="log_e" cellpadding="0" cellspacing="0">
                      <COL WIDTH=203><COL WIDTH=132><COL WIDTH=275>
                      <tr><td>Eingang</td><td>Init</td><td>Beschreibung</td></tr>
                      """+LOGIKINHTM.decode("iso-8859-1").encode("ascii","xmlcharrefreplace") +"""
                      </table>
                      <div class="field0">Ausg&#228;nge</div>
                      <a name="anker2" /><table border="1" width="612" class="log_a" cellpadding="0" cellspacing="0">
                      <tr><td>Ausgang</td><td>Init</td><td>Beschreibung</td></tr>
                      """+LOGIKOUTHTM.decode("iso-8859-1").encode("ascii","xmlcharrefreplace") +"""
                      </table>
                      <div class="field0">Sonstiges</div>
                      <div class="field1">Neuberechnung beim Start: """+CALCSTART+"""<br />Baustein ist remanent: """+LOGIKREMANT+"""<br />Interne Bezeichnung: """+LOGIKID+"""<br />Der Baustein wird im "Experten" in der Kategorie '"""+LOGIKCAT+"""' einsortiert.<br /></div>
                      </body></html>
                      if doDoku:
                      open("log"+LOGIKID+".html",'w').write(doku)
                      LIVECODE="""
                      if EN["""+str(ANZIN+1)+"""].find("<id"""+LOGIKID+""">")!=-1:
                      print "LivePort " +str(len(EN["""+str(ANZIN+1)+"""]))+ " Bytes erhalten"
                      try:
                      __LiveDebugCode_="".join(__import__('re').findall( "(?i)<id"""+LOGIKID+""">(.*)</id"""+LOGIKID+""">",EN["""+str(ANZIN+1)+"""]))
                      print "LiveDebug-Daten ID:"""+LOGIKID+" Name:"+LOGIKNAME+""" "
                      except:
                      pass
                      print "Fehler Datenlesen"
                      __LiveDebugCode_=''
                      if __LiveDebugCode_.find("<inject>") != -1:
                      SN["""+str(ANZSP+2)+"""]+="".join(__import__('re').findall("(?i)<inject> ([A-Za-z0-9\\x2B\\x3D\\x2F]+?)</inject>", __LiveDebugCode_))
                      print "Daten erhalten Buffer: " + str(len(SN["""+str(ANZSP+2)+"""]))
                      elif __LiveDebugCode_.find("<compile />") != -1:
                      print "Compile"
                      try:
                      __LiveBase64Code_=__import__('base64').decodestrin g(SN["""+str(ANZSP+2)+"""])
                      print __LiveBase64Code_
                      except:
                      pass
                      print "Base64 Error"
                      raise
                      try:
                      SN["""+str(ANZSP+1)+"""]=compile(__LiveBase64Code_,'<LiveDebug_"""+LOGIKID +""">','exec')
                      SC["""+str(ANZSP+1)+"""]=1
                      print "Running"
                      except:
                      pass
                      SN["""+str(ANZSP+1)+"""]="0"
                      print "Compile Error"
                      SN["""+str(ANZSP+2)+"""]=''
                      elif __LiveDebugCode_.find("<vars>") == 0:
                      print "Run Script"
                      try:
                      __LiveBase64Code_=__import__('base64').decodestrin g("".join(__import__('re').findall("(?i)<vars>([A-Za-z0-9\\x2B\\x3D\\x2F]+?)</vars>", __LiveDebugCode_)))
                      except:
                      pass
                      print "Script Base64 Error"
                      __LiveBase64Code_='0'
                      try:
                      eval(compile(__LiveBase64Code_,'<LiveDebugVars"""+ LOGIKID+""">','exec'))
                      except:
                      print "Script Error"
                      print __import__('traceback').print_exception(__import__ ('sys').exc_info()[0],__import__('sys').exc_info()[1],__import__('sys').exc_info()[2])
                      raise
                      else:
                      print "unbekanntes TAG: " + repr(__LiveDebugCode_)
                      #print LIVECODE
                      LOGIKFILE=LOGIKID+"_"+LOGIKNAME
                      ## Debug Lines
                      NCODE=[]
                      if debug or livedebug:
                      codepart[2]=re.sub("###DEBUG###","",codepart[2])
                      code=NCODE
                      #print "\n".join(code)
                      def commentRemover(code):
                      ## Komentar Remover
                      ## thanks to gaston
                      codelist=code[2].split("\n")
                      removelist=[]
                      lencode=len(codelist)-1
                      for i in range(1,lencode):
                      codeline=codelist[lencode-i].lstrip(" \t")
                      if len(codeline)>0:
                      if codeline[0]=='#':
                      removelist.insert(0,"REMOVED: ("+str(lencode-i)+") "+codelist.pop(lencode-i))
                      else:
                      return ([code[0],code[1],"\n".join(codelist)],"\n".join(removelist))
                      Nremoved=""
                      NCode=[]
                      codepart, removed=commentRemover(codepart)
                      Nremoved=Nremoved+removed
                      NCode.append(codepart)
                      code=NCode
                      #print Nremoved
                      #print "\n\n"
                      #print code
                      if livedebug:
                      NCODE="\n##### VERSION #### %04d-%02d-%02d %02d:%02d:%02d ###\n" % time.localtime()[:6]
                      code.append(NCODE)
                      CODELENGTH=len(repr(code))
                      breakStart=str((int(CALCSTARTBOOL)-1)*-1)
                      LOGIKARRAY=LOGIK.split("\n")
                      lformel=""
                      def compileMe(code,doByteCode,BEDINGUNG=''):
                      if doByteCode:
                      data=compile(code,"<"+LOGIKFILE+">","exec")
                      data=marshal.dumps(data)
                      version = sys.version[:3]
                      formel = ""
                      if doByteCode==2:
                      formel += "5012|0|\""+BEDINGUNG+"\"|\"eval(__import__('marsh al').loads(__import__('zlib').decompress(__import_ _('base64').decodestring('"+re.sub("\n","",base64. encodestring(zlib.compress(data,6)))+"'))))\"|\""+ ZEITFORMEL+"\"|0|"+ZEITSPEICHER+"|0|0"
                      else:
                      formel += "5012|0|\""+BEDINGUNG+"\"|\"eval(__import__('marsh al').loads(__import__('base64').decodestring('"+re .sub("\n","",base64.encodestring(data))+"')))\"|\" "+ZEITFORMEL+"\"|0|"+ZEITSPEICHER+"|0|0"
                      formel+="\n"
                      else:
                      if doCache:
                      LOGIKDEFARRAY=LOGIKARRAY[LHSDEFINELINE].split("|")
                      if livedebug:
                      LOGIKDEFARRAY[4]=str(ANZSP+2)
                      else:
                      LOGIKDEFARRAY[4]=str(ANZSP+1)
                      LOGIKARRAY[LHSDEFINELINE]="|".join(LOGIKDEFARRAY)
                      LOGIKARRAY[LSPDEFINELINE]+="\n"+"5003|"+str(ANZSP+1)+"|\"0\"|0 # Base64 Code-Cache"
                      if livedebug:
                      LOGIKARRAY[LSPDEFINELINE]+="\n"+"5003|"+str(ANZSP+2)+"|\"\"|0 # LivePortBase64Buffer"
                      if livedebug:
                      formel = "5012|0|\"EI or EC["+str(ANZIN+1)+"]\"|\"eval(compile(__import__('base64').decodestrin g('"+re.sub("\n","",base64.encodestring(LIVECODE)) +"'),'<"+LOGIKFILE+">','exec'))\"|\"\"|0|0|0|0\ n"
                      #formel += "5012|0|\"("+BEDINGUNG+") or SC["+str(ANZSP+1)+"]\"|\"eval(SN["+str(ANZSP+1)+"])\"|\""+ZEITFORMEL+"\"|0|"+ZEITSPEICHER+"|0|0"
                      formel += "5012|0|\"\"|\"eval(SN["+str(ANZSP+1)+"])\"|\""+ZEITFORMEL+"\"|0|"+ZEITSPEICHER+"|0|0"
                      else:
                      formel = "5012|0|\"EI\"|\"compile(__import__('base64').deco destring('"+re.sub("\n","",base64.encodestring(cod e))+"'),'<"+LOGIKFILE+">','exec')\"|\"\"|0|0|"+str (ANZSP+1)+"|0\n"
                      formel += "5012|0|\""+BEDINGUNG+"\"|\"eval(SN["+str(ANZSP+1)+"])\"|\""+ZEITFORMEL+"\"|0|"+ZEITSPEICHER+"|0|0"
                      else:
                      formel = "5012|0|\""+BEDINGUNG+"\"|\"eval(compile(__import_ _('base64').decodestring('"+re.sub("\n","",base64. encodestring(code))+"'),'<"+LOGIKFILE+">','exec')) \"|\""+ZEITFORMEL+"\"|0|"+ZEITSPEICHER+"|0|0"
                      #formel+="\n## MD5 der Formelzeile: "+md5.new(formel).hexdigest()
                      return formel
                      formel=""
                      for i in range(len(code)):
                      codepart=code[i]
                      if codepart[0]==1:
                      tempBC=1
                      if codepart[0]==2:
                      tempBC=2
                      else:
                      tempBC=doByteCode
                      if livedebug:
                      doCache=True
                      formel=compileMe(LIVECODE,False,BEDINGUNG="")
                      break
                      formel+=compileMe(codepart[2],tempBC,BEDINGUNG=codepart[1])
                      #formel+=commentcode[i]+"\n\n"
                      ### DEBUG ###
                      formel+="\n"+postlogik[2]
                      ## Debuggerbaustein
                      if livedebug:
                      LOGIKDEFARRAY=LOGIKARRAY[LEXPDEFINELINE].split("|")
                      LOGIKDEFARRAY[3]=str(ANZIN+1)
                      LOGIKDEFARRAY[3+ANZIN]+="|\"E"+str(ANZIN+1)+" DEBUG\""
                      LOGIKARRAY[LEXPDEFINELINE]="|".join(LOGIKDEFARRAY)
                      LOGIKDEFARRAY[1]=str(ANZIN+1)
                      LOGIKARRAY[LINDEFINELINE]+="\n"+"5002|"+str(ANZIN+1)+"|\"\"|1 # Debugger Live in"
                      LOGIK = "\n".join(LOGIKARRAY)
                      allcode=""
                      for i in code:
                      allcode+=i[2]+"\n"
                      if showList:
                      codeobj=allcode.split("\n")
                      for i in range(0,len(codeobj)):
                      print str(i)+": "+codeobj[i]
                      if debug and not livedebug:
                      debugstart=time.clock()
                      allcode += debugcode
                      if not noexec:
                      exec(allcode)
                      else:
                      compile(allcode,"<code>","exec")
                      debugtime=time.clock()-debugstart
                      print "Logikausfuehrzeit: %.4f ms" % (debugtime)
                      if debugtime>1:
                      print """
                      ### !!!ACHTUNG: sehr lange Ausfürungszeit!! ###
                      if debug or doSend:
                      del EN[0]
                      del SN[0]
                      del AN[0]
                      if livedebug:
                      #formel=lformel
                      LOGIK="""############################\n#### DEBUG BAUSTEIN #######\n############################\n"""+LOGIK
                      livesend=re.sub("\n","",base64.encodestring(allcod e))
                      sock = socket.socket(socket.AF_INET,socket.SOCK_DGRAM)
                      sock.connect((livehost,liveport))
                      Livepackets=0
                      while livesend!="":
                      Livepackets+=1
                      sock.sendall("<xml><id"+LOGIKID+"><inject>"+livese nd[:4000]+"</inject></id"+LOGIKID+"></xml>")
                      livesend=livesend[4000:]
                      time.sleep(0.1)
                      time.sleep(1)
                      sock.sendall("<xml><id"+LOGIKID+"><compile /></id"+LOGIKID+"></xml>")
                      print str(Livepackets)+ " Packet per UDP verschickt"
                      sock.close()
                      if doSend:
                      ## Das auslösen über den Debug verhindern
                      sendVars="EC["+str(ANZIN+1)+"]=0\n"+sendVars
                      sock.sendall("<xml><id"+LOGIKID+"><vars>"+re.sub(" \n","",base64.encodestring(sendVars)+"</vars></id"+LOGIKID+"></xml>\n"))
                      sock.close()
                      if VERSION !="":
                      VERSION="_"+VERSION
                      if debug:
                      VERSION+="_DEBUG"
                      open(LOGIKFILE+VERSION+".hsl",'w').write(LOGIK+"\n "+formel+"\n")
                      def md5sum(fn):
                      m = md5()
                      f=open(fn,'rb')
                      while True:
                      data = f.read(1024)
                      if not data:
                      break
                      m.update(data)
                      f.close()
                      return m.hexdigest() + " *" + fn + "\n"
                      #chksums = md5sum(LOGIKFILE+VERSION+".hsl")
                      #if not nosource:
                      # chksums += md5sum(inspect.currentframe().f_code.co_filename)
                      #if doDoku:
                      # chksums += md5sum("log"+LOGIKID+".html")
                      #open(LOGIKFILE+".md5",'w').write(chksums)
                      if doZip:
                      #os.remove(LOGIKFILE+VERSION+".zip")
                      z=zipfile.ZipFile(LOGIKFILE+VERSION+".zip" ,"w",zipfile.ZIP_DEFLATED)
                      if not nosource:
                      z.write(inspect.currentframe().f_code.co_filename)
                      if doDoku:
                      z.write("log"+LOGIKID+".html")
                      z.write(LOGIKFILE+VERSION+".hsl")
                      # z.write(LOGIKFILE+".md5")
                      z.close()
                      print "Baustein \"" + LOGIKFILE + "\" erstellt"
                      print "Groesse:" +str(CODELENGTH)
                      if livedebug:
                      print "########################################"
                      print "#### DEBUGBAUSTEIN ####"
                      print """
                      Kategorie: '"""+LOGIKCAT+"""'
                      Anzahl Eingänge: """+str(ANZIN)+""" """+repr(EN)+"""
                      Anzahl Ausgänge: """+str(ANZOUT)+""" """+repr(AN)+"""
                      Interne Speicher: """+str(ANZSP)+""" """+repr(SN)+"""
                      #print chksums
