Urgent question about Zeitschaltuhr with day and hour
    Hello,
    Does someone know how to use the Zeitschaltuhr Logic Module (see picture) in HomeServer to configure this basic function:
    When I press to a button (send 1) --> Switch ON (every Friday at 15h)
    When I press to the same button (send 0) --> disable this option (do nothing)
    I read the module help but I don't found the answer (I don't understand German)..
    Can you make me a screenshot of the logic function please?
    Thank you!!!
    I'm not using this logic unit myself, but this should be very simple:
    - Connect the KO with the enable/disable button to "Schaltuhr ein/ausschalten". This will enable or disable the clock entirely.
    - Set "Jeden Freitag" to "1" by double clicking the named input and enter a "1" ("only fridays").
    - Set "von Stunde" to "15" accordingly ("do it at 15:00h").
    - The output "an/aus" is the resulting timer function.
    Greetings
    Hartmut
      Hello,
      Thank you for your help.. It works fine..
      For 15h30 I need to select:
      Von Stunde 15
      Bis Stunde 16
      Von Minute 30
      Best Regards!!
