KNX to UPNP (for Sonos) communication (SoCo?)
    HS/FS KNX to UPNP (for Sonos) communication (SoCo?)
    Hello,
    I'd like to use the Gira HS to expose some KNX group address that would act on some UPNP devices (Sonos).
    The scenario is that I'd like to have some wall switches send datagrams that would increase/decrease the volume of sonos devices, switch them off, etc.
    First question: is there a ready-to-use solution for this?
    If not, I saw that there is the SoCo Pyhton code (https://github.com/rahims/SoCo) which could be used for that but how would I then integrated that Pyhton library into the Gira server? I didn't see some ".hsl" package that I could import directly in Gira.
    Any Idea? That must be a recurring topic but I haven't found a definitive and clear answer.
    Thanks,
    sacha
    Here you go: https://knx-user-forum.de/knx-eib-fo...oneplayer.html
      Thanks Shipsy, I had found this one but it says it links to the "Downloadbereich" but when you click on the link it actually sends to you the web site of the author where you can buy a license key. Did I look at the wrong place and the logic is still available for download?
      Since my needs are very limited (volume up/down + shut-down for a single device), I didn't want to "license" something, but just find a way to send the proper UPNP commands (I couldn't find a way to craft a proper SOAP message within the Expert (it seems I am not able to define HTTP Headers in "Communications/Web Pages/IP Devices" and I am not sure how to create a custom Python HTTP query from a HSL file)
