HS Logik Python Module Import
    HS/FS HS Logik Python Module Import
    Hello,
    I am writing a HSL file and need to use/import a Python library that is not installed by default with the HS AFAICT (the "Requests" library i.e. Requests: HTTP for Humans ? Requests 2.1.0 documentation)
    How can I do that?
    I discovered that it is possible to embed full-fledge Python in the HSL by using the "encode("xxx")" "trick", so I was wondering if there was a similar trick for embedding a Python library.
    Thanks in advance!
    Sacha
    I'm aware that this post is seven years old... But I'll just ask, is it possible to embed the Requests library in a HS Logic module?
    I have a use case where the urllib is not working (on any platform...)
      It is possible to use python libs with HS version 4.7 and newer. You can find some examples and the documentation under developer.gira.com (HSL2.0)
