HS logic: basic question about file management
    Zitat von MatthiasS Beitrag anzeigen
    The only way, and so I did with hs2wav and wetter2hs, is to send an IP telegram to your external application, make some calculations and deliver the result back the same way.
    Hi Matthias,
    Can you elaborate a little bit on this, please ?
    Just to get me started.
    An example would help a lot.
    Thank you.
      What do my tired eyes encounter here? HURRAY HURRAY, praise the lord
      I did not dive too deep into HS logic yet, but since I'm a software developer at my second task beside working on my house (or was it the other way around? ) I would definitely favour scripting over the logic editor.
      Any prophecies on when this could become reality? So that one can decide what tasks to delay...
      cu,
      __
      /homas
      And don't believe, that todays limited access to python inside hs will be limited the same way forever!
        Well, do not attempt to dive too deep, in this thing
        it's a rocky bottom, you know !
        You'll break your neck in no time
