I've a bizarre problem in my EIB installation.
Since several days, when I click on an icon in the HS Visu to switch On a lamp, it doesn't work well. Sometimes, I've to click several times before it works.
I've started the ETS bus monitor, nothing special, usage is at 3-4% average (some lines are green, any special meaning ?)
When I hit a PB, I see the traffic on the bus. So the EIB part seems OK.
When I click on an icon in the Visu nothing happens, it is as if the HS has become very very slow.
In the HS Debug, I can't see any obvious errors:
Stamm-Error: nothing
Memory free: 87863296
I can't remember of any serious modifications in my installation.
So far, I've replaced the network cable, used another port of the switch, no result
How could I start troubleshooting ? especially testing the FT 1.2 that connects the HS to the bus ?
Thank you in advance for any hint.
Then I learnt (admittedly my way of coding is mostly based on trial&error) that it's very useful for debugging logics, without putting everything on i.e. the Visu..
