- √ - Anwesenheitssimu
Dieses Thema ist geschlossen.
    [wiregate] - √ - Anwesenheitssimu
    hier ein Skript für eine simple Anwesenheitssimulation:
    use Time::Local;
    $plugin_info{$plugname.'_cycle'} = 60;   # Aufruf Zyklus auf 120s setzen
    my @ga = qw(4/0/0 4/4/4 1/1/1 1/1/12 1/1/18 1/1/8);  # Diese GAs werden geschalten
    my $starttime = "18:30:00";               # Beginn Simulation
    my $durationmin = "240";                  # Ende der Simulation nach xxx Minuten
    my $holidaystart = "13.02.2014 00:00:00"; # In dieser Zeit Simu
    my $holidayend   = "16.02.2014 23:59:00"; # In dieser Zeit Simu
    my $weekdaystart = "1,2..4";              # Falls kein Urlaub, trotzdem an diesen Tagen die Simu starten (Mon => "1"  So => "7")
    my ($second, $minute, $hour, $dayOfMonth, $month, $year, $yearOffset, $dayOfWeek, $dayOfYear, $daylightSavings);
    my ($timestamp, $datestamp, $isTime, $isSimuDay, $isHoliday, $endtime, $switchofftime, $currentunix, $u_starttime);
    my ($wuerfel,$msg,$status);
    sub get_time() {
      ($second, $minute, $hour, $dayOfMonth, $month, $yearOffset, $dayOfWeek, $dayOfYear, $daylightSavings) = localtime();
      $year = 1900 + $yearOffset;
      $month = $month+1;
      $minute = "0".$minute if ($minute < 10);
      $hour = "0".$hour if ($hour < 10);
      $month = "0".$month if ($month < 10);
      $dayOfMonth = "0".$dayOfMonth if ($dayOfMonth < 10);
      $timestamp = "$year$month$dayOfMonth $hour:$minute:$second";
      $datestamp = "$dayOfMonth.$month.$year $hour:$minute:$second";
      $u_starttime = &unixdatum("$dayOfMonth.$month.$year $starttime");
      $durationmin *= 60;
      $endtime = ($u_starttime+$durationmin);
      $switchofftime = ($endtime-2*$plugin_info{$plugname.'_cycle'});
    sub unixdatum() {
      my $dvalue = "@_";
      my ($datum,$uhrzeit) = split(/ /,$dvalue);
      my ($tag,$monat,$jahr)=split(/\./,$datum);
      my ($std,$min,$sek)  = split(/:/,$uhrzeit);
      my $unixtime = timelocal($sek,$min,$std,$tag,$monat,$jahr);
      return $unixtime;
    sub check_start() {
      my @weekarray=eval $weekdaystart;
      $currentunix=&unixdatum($datestamp);
      $isTime = "true" if (($currentunix ge $u_starttime) and ($currentunix le $endtime));
      foreach my $weekarray (@weekarray) {
        next unless ($weekarray eq $dayOfWeek);
        $isSimuDay="true";
      if  (( &unixdatum($datestamp) ge &unixdatum($holidaystart) ) and ( &unixdatum($datestamp) le &unixdatum($holidayend) )) {
            $isHoliday = "true";
    sub switch_on_off() {
      my $action = "@_";
      my $anz_ga = $#ga;
      my $number = int(rand $anz_ga+1);
      my $random_ga = $ga[$number];
      foreach my $current_ga (@ga) {
          ###### alle ausschalten
          if ( $action eq "off" ) {;
                knx_write($current_ga,0,1);
                $msg="switching all off ...";
                next;
          ###### random an-/ausschalten
          if ( ("$current_ga" eq "$random_ga") and ($action eq "random") ) {
                 my $laststate = knx_read($current_ga,3600,1);
                 knx_write($current_ga,0,1) if ($laststate eq "1");
                 $msg="switching $current_ga off ..." if ($laststate eq "1");
                 knx_write($current_ga,1,1) if ($laststate eq "0");
                 $msg="switching $current_ga on ..." if ($laststate eq "0");
    # MAIN
    &get_time;
    &check_start;
    #print "isSimuDay: $isSimuDay \nisHoliday: $isHoliday \nisTime:    $isTime \n";
    $status = "active";
    if ( ($isSimuDay ne "true") and ($isHoliday ne "true") ) {
        $msg = "inactive ...";
        $status = "inactiv";
    if ($isTime ne "true") {
        $msg =  "active today at $starttime ...";
    if ($currentunix ge $switchofftime) {
        &switch_on_off("off") if ($status eq "active");
    } elsif ($status eq "active") {
        # Zufallszahl zwischen 0 und 5 erzeugen, je hoeher die random zahl desto seltener wird geschalten
        $wuerfel = int(rand 6);
        if ($wuerfel eq "0") {
           &switch_on_off("random");
        } else {
           $msg="active ...";
    print "$msg \n";
    return $msg;
    Uwe
    ..würde das mal - unbewertet und ungetestet - als Anwesenheitssimulation2.pl ins SVN der WG-Plugins schieben?
    Open Automation / Code / [r2071] /wiregate/plugin/generic
    Weil sonst geht das unter..
    Lieber ist uns natürlich wenn man das selbst macht, Sourceforge-Account, Rechte gibts von ChrisM oder mir.
    Aber SVN ist nicht jedermanns Sache, was ich absolut verstehe
    Makki
    -> Bitte KEINE PNs!
      ja, gute Idee ...
      Das Skript läuft bei mir einwandfrei. Für die Anpassung muss eigentlich nur die Zeile "my @ga =" angepasst werden (und natürlich die Startzeiten und Dauer je nach Gusto)
      Uwe
        Erledigt.. Open Automation / Code / Commit [r2072]
        P.S.: Halte mal ein Auge auf den Speicher"verbrauch", ich habe subs immernoch in Verdacht da was wegzuessen..
        Makki
        -> Bitte KEINE PNs!
          Hallo Uwe,
          willst Du vielleicht noch kurz erzaehlen, was das Script kann und macht?
          Waere praktisch, damit sich nicht jeder erst den Code angucken muss.
          Danke.
          Manuel
            Zitat von nipponichi Beitrag anzeigen
            angucken
            ... und verstehen ... ;-)
              kurze Erklärung zum Skript:
              es ist zwischen $holidaystart und $holidayend und zusätzlich an den Tagen in $weekdaystart aktiv. Also gemäß Code oben zwischen dem 13.02 und 16.02 sowie jede Woche Mo und Di-Do (hätte man auch als "$weekdaystart=1-4;" angeben können oder leer wenn man die Simu nur für den Urlaub aktivieren will).
              Um 18:30 beginnt dann die Simulation und dauert bis 22:30 (= 240min)
              In dieser Zeit werden die Lampen die in @ga eingetragen sind geschalten. Dazu ist erstmal ein Zufallsgenerator aktiv "$wuerfel = int(rand 6);" der nur bei einer "0" überhaupt was macht.
              Ein weiterer Zufallsgenerator wählt die zu schaltende Lampe ("my $number = int(rand $anz_ga+1); my $random_ga = $ga[$number]; ) der die Lampe je nach vorherigem Zustand entweder ein- oder ausschaltet. Um 22:30 wird dann alles komplett ausgeschaltet.
              Ich hoffe das hilft ...
              Uwe
                Nachtrag:
                muß geändert werden in
                if ( ($isTime ne "true") and ($status eq "active") ) {
                hat zwar keine Auswirkung auf die Funktion, jedoch ist sonst die Rückgabeinfo inkorrekt
                Uwe
                  Irgendwas stimmt nicht an dem Script. Seit Dezember hab ich folgende Fehlermeldung:
                  Run-time: Month '12' out of range 0..11 at (eval 19846) line 53 0
                  # https://knx-user-forum.de/wiregate/33115-anwesenheitssimu.html
                  # by uxtuner (Uwe)
                  use Time::Local;
                  my @ga = qw(1/0/100 1/0/20 1/1/0 1/1/50 1/0/130);  # Diese GAs werden geschalten
                  my $starttime = "16:30:00";               # Beginn Simulation
                  my $holidaystart = "06.12.2014 00:00:00"; # In dieser Zeit Simu
                  my $holidayend   = "07.12.2014 23:59:00"; # In dieser Zeit Simu
                  my $weekdaystart = "6,7";              # Falls kein Urlaub, trotzdem an diesen Tagen die Simu starten (Mon => "1"  So => "7")
                  sub get_time() {
                    $month = $month+1;
                    $durationmin *= 60;
                  sub unixdatum() {
                    my $dvalue = "@_";
                    return $unixtime;
                  sub check_start() {
                      $isSimuDay="true";
                    my $action = "@_";
                    my $anz_ga = $#ga;
                              next;
                  # MAIN
                  &get_time;
                  &check_start;
                  $status = "active";
                      } else {
                         $msg="active ...";
                  print "$msg \n";
                  return $msg;
                    Ich könnte jetzt schreiben "markier doch wenigstens Zeile 53" oder "der Fehler ist doch gut beschrieben" aber ich schreib:
                    Der Code
                    stimmt anscheinend nicht, weil timelocal die Monatswerte 0 bis 11 erwartet und nicht 12 für Dezember. Ist wohl nie aufgefallen, weil nur wieder mit ebenfalls falschen Daten verglichen bzw. eine Zeitspanne berechnet wird.
                    Lösung einfach 1 abziehen vom Monat:
                    my $unixtime = timelocal($sek,$min,$std,$tag,$monat - 1,$jahr);
                      Hi!
                      Danke sehr - hatte das selbe Problem
                      lg
                      KNX, DMX, 1Wire, WireGate, CometVisu
                        Jetzt passts.. Danke
