Russound RIO <-> HS
    HS/FS Russound RIO <-> HS
    wer hat seinen Russound C5 über das RIO-Protokoll an den Homeserver angebunden ?
    Gibt es hier schon fertige Bausteine/Lösungen ?
    Danke !!
    Jörg
    Russound RIO &lt;-&gt; HS
    Norbe hat das glaub mal versucht. Mit sh.py läuft das bei mir nun über einem Jahr problemlos. Zur Not musst dir halt noch nen Pi kaufen
    Mit freundlichen Grüßen
    Niko Will
      mit IP-Telegrammen ja
      Baustein gibt's keinen, dafür war mir der Aufwand zu groß
      ____________
      Gruss Norbe
        I believe there are some logic modules around but none of them are supported nor published.
        The HS seems to be the only device that doesn't have a plugin for the Russound available.
        Maybe Nils can use his Bytecode logic to connect to the Russound with an xml output since the Russound protocol is very easy. He has it working on a Marantz/Denon.
        It would not be to difficult to parse the XML into GA's to be usable in a visu.
        As I see a lot of people are using the Russound devices MCA-C5 and C3. So this would be a very popular module. I'm surprised nobody took up the task to make and support one. We have some very skilled programmers here with HS knowledge but maybe no MCA??
        Is somebody using a MCA-C5 with a DMS3.1 and controlling it with the Gira HS?
          Hi Norbe,
          hast du eventuell deine Lösung dokumentiert ? Hast du auch einen DMS,
          welcher so gesteuert werden könnte ?
          VG,
          lumo
