Hello.
I've installed the EIBD on my raspberry pi with wheezy, newest build...
Done like described here:
SourceForge.net: Install Eibd/Linknx/knxweb - linknx
When coming to the line, where i can test the EIBD i get an error.
I connect using TCP/IP, by doing "eibd -d -D -S -T -i ipt:192.168.1.10:3671"
I don't get any errors, so i think it accepts my command. But sometimes i get an error "eibd: error when loading shared libraries: libpthsem.so.20", depending on which directory i am in when executing the eibd command - is that correct? If i am in the pthsem-2.0.8 it works.
I try to use the groupswrite to send a ON/OFF command to my KNX installation:
groupswrite ip:127.0.0.1 1/0/0 1 i get reply: "Send Request" - and nothing happens.
groupswrite ip:127.0.0.1 1/0/0 1 1 i get reply: "usage: groupswrite url eibaddr val: Succes"
But nothing happens - please help
