ETS4 : An internal device error occurred
    KNX/EIB ETS4 : An internal device error occurred
    Hallo!
    Ich bin ganz neu beim KNX welt.
    Ich wollte es probieren und habe ich mich das folgende angeschlossen:
    PC(ETS4) -> RaspberryPi/RTC-OneWire-TPUART(SmartHome.py) -> Hager TXA111 -> Hager TXA204A
    Beim Downloaden von Application in den TXA204A macht der ETS4 ein "Internal device error occurred".
    2014-03-19 21:59:42,951 [17] INFO DevManagement - CompareMem($B6EC...$B6EC) 02
    2014-03-19 21:59:43,308 [17] INFO NetworkBridgeFalcon - ReadMem(RCo$1103:01FA825C, $B6EC...$B6EC): S_OK
    2014-03-19 21:59:43,310 [17] INFO DevManagement - ReadMem($B6EC...$B6EC) 03
    2014-03-19 21:59:43,311 [17] WARN DevManagement - CompareMem($B6EC...$B6EC) verify failed at $B6EC: $03/$02
    2014-03-19 21:59:43,312 [17] INFO DevManagement - CompareMem($B6EC...$B6EC) 02
    2014-03-19 21:59:43,567 [17] INFO NetworkBridgeFalcon - ReadMem(RCo$1103:01FA825C, $B6EC...$B6EC): S_OK
    2014-03-19 21:59:43,568 [17] INFO DevManagement - ReadMem($B6EC...$B6EC) 03
    2014-03-19 21:59:43,569 [17] WARN DevManagement - CompareMem($B6EC...$B6EC) verify failed at $B6EC: $03/$02
    2014-03-19 21:59:43,570 [17] INFO DevManagement - CompareMem($B6EC...$B6EC) 02
    2014-03-19 21:59:43,972 [17] INFO NetworkBridgeFalcon - ReadMem(RCo$1103:01FA825C, $B6EC...$B6EC): S_OK
    2014-03-19 21:59:43,974 [17] INFO DevManagement - ReadMem($B6EC...$B6EC) 03
    2014-03-19 21:59:43,975 [17] WARN DevManagement - CompareMem($B6EC...$B6EC) verify failed at $B6EC: $03/$02
    2014-03-19 21:59:43,976 [17] ERROR DevManagement - WriteLoadControl(3,3) failed
    2014-03-19 21:59:43,979 [17] ERROR Adm1Interpreter - Load control 'AbsDataSeg 3 addr=$0700-0777, access=$00, memtype=$02, flags=$00' failed: HAWK_E_DEVICE_CONTROL_FAILED
    2014-03-19 21:59:43,980 [17] INFO DevManagement - Disconnect(01.01.003)
    2014-03-19 21:59:44,099 [17] INFO NetworkBridgeFalcon - FalconConnection!Close RCo$1103:01FA825C
    2014-03-19 21:59:44,100 [17] INFO Adm1Interpreter - End Execute (hr=HAWK_E_DEVICE_CONTROL_FAILED)
    2014-03-19 21:59:44,101 [17] INFO LoadDeviceTask - Download - Enter LoadDeviceTask::RunFinal(01.01.003, None)
    2014-03-19 21:59:44,103 [17] INFO LoadDeviceTask - Setting Programming Flags ($1103): Addr=1, Cfg=1, Appl=0, Par=0, Grp=0, Img=null, Chksum=null
    2014-03-19 21:59:44,325 [17] INFO LoadDeviceTask - Download - Leave LoadDeviceTask::RunFinal(01.01.003, None)
    2014-03-19 21:59:44,327 [17] ERROR Knx.Ets.UI.Deagle.PendingOperation - Error during executing RunFinalPhase() method of object rr: An internal device error occurred.
    Um was könnte diese Problem kommen?
    Ich habe auch ein Hager TXA201 angeschlossen und da ist kein error gekommen, auch nicht ein Warning.
    Danke für die Hilfe!
