Creating help files for own Baustein
    HS/FS Creating help files for own Baustein
    I've a problem writing the help files for my own Baustein.
    Sometimes it works, sometimes not, but I've no clue as to what is the cause.
    For a given Baustein, i.e. 13050_ABC.hsl, I've created a help file log13050.html
    When I start the log13050.html file with IE, I see a normal web page with the relevant help info about the Baustein.
    Then I quit & restart the Experte, go to le Logic Editor, load the Baustein, right click, there is no help available.
    Even more, when I take a known good help file (from another Baustein), just rename it as log13050.html, it doesn't work.
    I guess there is something wrong with the format of my .html file.
    Any pointer to a doc to read about the format ?
    Any hint about the editor to use ? (FrontPage seems to add a hype of useless stuff, usually I get a file size of 24K, vs 4-5K for standard help file with same info.
    PS: I know the topic has already been discussed but can't find it back.
    I had no problems with this so far, as soon as you put an according logXXXXX.html in the hlp-Dir its diaplyed in Experte even without restart..
    I always copied existing ones and use Editplus for editing, maybe Frontpage trashed them (which is likely, as it's not very related to what HTML is about
    Makki
    -> Bitte KEINE PNs!
      Aaargh
      Guess who has put them in the "logic" directory
      No, this time FrontPage is not to blame (rather me )
      Thank you very much
