Import from ETS: Uncertain (4 Byte)
    I noticed a bizarre thing with the ABB AE/A 2.1
    When looking in ETS, I see the KO with their respective data type, i.e. #0 Output Value, 2 Byte
    When looking in the HS, they are 4 Byte !!!
    So I took a look at the .esf file, used for importing KO from ETS to the HS, and there is says "Uncertain (4 Byte)"
    Bizarre ! is this normal behaviour or maybe wrong manipulation on my side ?
    Thank you for any hint.
    Hi
    change the typ in in the HS,then look what happens
    Andreas
    Gruss Aendu
    HS3/HS2/Pronto/.......
      OK, if I mimic the settings seen in ETS in the HS, sure it will work.
      But the question was rather "how come" ?
      If the ETS says 2 byte, and after the import process it becomes "uncertain", well I question the import process.
      Any idea ?
        Sorry , i dont have a idee.
        but ask the Gira Support
        http://www.gira.de/kontakt/deutschland.html
        Andreas
        Gruss Aendu
