Smarthome Raspberry Dummy
    KNX/EIB Smarthome Raspberry Dummy
    Leider bekomme ich auch nicht das Licht eingeschaltet.
    Browser: Firefox
    WINSCP
    Meine item sieht wie folgt aus.
    [EG]
    [[Wohnzimmer]]
    [[[Decke]]]
    type = bool
    visu_acl = rw
    knx_dpt = 1
    knx_listen = 1/1/37
    knx_send = 1/1/36
    knx_init = 1/1/36
    Meine Page sieht wie folgt aus
    * @package     smartVISU
    * @author      Martin Gleiß
    * @copyright   2012
    * @license     GPL [http://www.gnu.de]
    {% extends "rooms.html" %}
    {% block content %}
      <div class="block">
       <div class="set-2" data-role="collapsible-set" data-theme="c" data-content-theme="a" data-mini="true">
          <div data-role="collapsible" data-collapsed="false">
              <h3>Wohnzimmer</h3>
                 <table width=100%>
                   <tr>
                     <td align=left>
                       {{ basic.switch('S1', 'EG.Wohnzimmer.Decke', icon1~'light_light.png', icon0~'light_light.png') }} Deckenlicht
                     </td>
                   </tr>
                 </table>
          </div>
        </div>
        </div>
    {% endblock %}
    Mein Debug sieht wie folgt aus
    2014-04-28 19:51:46,097 INFO     Main         Start SmartHome.py 1.0-32-gfd0043e -- smarthome.py:__init__:231
    2014-04-28 19:51:46,101 DEBUG    Main         Python 3.2.3 -- smarthome.py:__init__:232
    2014-04-28 19:51:46,107 INFO     Main         Init Scheduler -- scheduler.py:__init__:86
    2014-04-28 19:51:46,113 INFO     Main         Init Plugins -- smarthome.py:start:274
    2014-04-28 19:51:46,125 DEBUG    Scheduler    creating 5 workers -- scheduler.py:run:93
    2014-04-28 19:51:46,135 DEBUG    Main         Plugin: knx -- plugin.py:__init__:43
    2014-04-28 19:51:46,164 DEBUG    Main         Plugin: visu -- plugin.py:__init__:43
    2014-04-28 19:51:46,257 DEBUG    Main         Plugin: cli -- plugin.py:__init__:43
    2014-04-28 19:51:46,269 DEBUG    Main         Plugin: sql -- plugin.py:__init__:43
    2014-04-28 19:51:46,302 DEBUG    Main         SQLite 3.7.13 -- __init__.py:__init__:62
    2014-04-28 19:51:46,538 DEBUG    Main         SQLite: database integrity ok -- __inits__.py:__init__:78
    2014-04-28 19:51:46,579 DEBUG    Main         SQLite pack next time: 2014-04-29 03:02:00+02:00 -- scheduler.py:_next_time:289
    2014-04-28 19:51:46,585 INFO     Main         Init Items -- smarthome.py:start:280
    2014-04-28 19:51:46,708 DEBUG    Main         Item env.core.memory = 13402112.0 via SQLite None None -- item.py:set:457
    2014-04-28 19:51:46,778 DEBUG    Main         Item env.core.threads = 7.0 via SQLite None None -- item.py:set:457
    2014-04-28 19:51:46,844 DEBUG    Main         Item env.core.garbage = 0.0 via SQLite None None -- item.py:set:457
    2014-04-28 19:51:46,851 DEBUG    Main         Item env.core: no type specified. -- item.py:__init__:242
    2014-04-28 19:51:46,907 DEBUG    Main         Item env.location: no type specified. -- item.py:__init__:242
    2014-04-28 19:51:46,979 DEBUG    Main         Item env.system.load = 0.27 via SQLite None None -- item.py:set:457
    2014-04-28 19:51:46,991 DEBUG    Main         Item env.system: no type specified. -- item.py:__init__:242
    2014-04-28 19:51:46,995 DEBUG    Main         Item env: no type specified. -- item.py:__init__:242
    2014-04-28 19:51:47,015 DEBUG    Main         KNX: EG.Wohnzimmer.Decke listen on 1/1/37 -- __init__.py:parse_item:235
    2014-04-28 19:51:47,019 DEBUG    Main         KNX: EG.Wohnzimmer.Decke listen on and init with 1/1/36 -- __init__.py:parse_item:244
    2014-04-28 19:51:47,023 DEBUG    Main         Item EG.Wohnzimmer: no type specified. -- item.py:__init__:242
    2014-04-28 19:51:47,027 DEBUG    Main         Item EG: no type specified. -- item.py:__init__:242
    2014-04-28 19:51:47,034 INFO     Main         Start Plugins -- plugin.py:start:65
    2014-04-28 19:51:47,081 INFO     Main         Start Logics -- logic.py:__init__:33
    2014-04-28 19:51:47,085 DEBUG    Main         Reading Logics from /usr/smarthome/lib/env/logic_conf -- logic.py:_read_logics:64
    2014-04-28 19:51:47,118 DEBUG    Main         Reading Logics from /usr/smarthome/etc/logic.conf -- logic.py:_read_logics:64
    2014-04-28 19:51:47,136 DEBUG    Main         Logic: hello -- logic.py:__init__:44
    2014-04-28 19:51:47,195 DEBUG    Main         Logic: env_init -- logic.py:__init__:44
    2014-04-28 19:51:47,207 DEBUG    Main         Logic: env_stat -- logic.py:__init__:44
    2014-04-28 19:51:47,247 DEBUG    Main         env_stat next time: 2014-04-28 19:52:00+02:00 -- scheduler.py:_next_time:289
    2014-04-28 19:51:47,266 DEBUG    Main         Logic: env_loc -- logic.py:__init__:44
    2014-04-28 19:51:47,346 DEBUG    Connections  KNX: connected to 127.0.0.1:6720 -- connection.py:connect:386
    2014-04-28 19:51:47,351 DEBUG    Connections  KNX: enable group monitor -- __init__.py:handle_connect:117
    2014-04-28 19:51:47,354 DEBUG    Connections  KNX: init read -- __init__.py:handle_connect:123
    2014-04-28 19:51:47,361 DEBUG    Connections  WebSocket: binding to 0.0.0.0:2424 (TCP) -- connection.py:connect:161
    2014-04-28 19:51:47,367 DEBUG    Connections  CLI: binding to 0.0.0.0:2323 (TCP) -- connection.py:connect:161
    2014-04-28 19:51:48,333 DEBUG    Main         KNX: 0.0.0 read 1/1/36 -- __init__.py:parse_telegram:203
    2014-04-28 19:51:51,271 DEBUG    Main         knx: 1.1.15 set 3/1/4 to 076c -- __init__.py:parse_telegram:181
    2014-04-28 19:51:52,248 INFO     hello        Hello World! -- hello.py:<module>:3
    2014-04-28 19:51:52,253 DEBUG    env_init     Item env.core.version = 1.0-32-gfd0043e via Logic None None -- item.py:__update:363
    2014-04-28 19:51:52,265 DEBUG    env_init     Item env.core.start = 2014-04-28 19:51:52.260940+02:00 via Logic None None -- item.py:__update:363
    2014-04-28 19:51:52,274 DEBUG    env_init     Item env.system.name = smarthome.local via Logic None None -- item.py:__update:363
    2014-04-28 19:51:52,286 DEBUG    env_init     Item env.system.start = 2014-04-28 19:50:53.281922+02:00 via Logic None None -- item.py:__update:363
    2014-04-28 19:51:52,834 DEBUG    env_loc      Item env.location.sunrise = 2014-04-29 05:54:56.120459+02:00 via Logic None None -- item.py:__update:363
    2014-04-28 19:51:52,836 DEBUG    sh.gc        Garbage collector: collected 0 objects. -- smarthome.py:_garbage_collection:498
    2014-04-28 19:51:52,879 DEBUG    env_loc      Item env.location.sunset = 2014-04-28 20:35:38.225778+02:00 via Logic None None -- item.py:__update:363
    2014-04-28 19:51:52,963 DEBUG    env_loc      Item env.location.moonrise = 2014-04-29 06:04:49.214095+02:00 via Logic None None -- item.py:__update:363
    2014-04-28 19:51:53,043 DEBUG    env_loc      Item env.location.moonset = 2014-04-29 21:01:01.387769+02:00 via Logic None None -- item.py:__update:363
    2014-04-28 19:51:53,081 DEBUG    env_loc      Item env.location.moonphase = 8 via Logic None None -- item.py:__update:363
    2014-04-28 19:51:53,151 DEBUG    sh.gc        Object references: 8957 -- smarthome.py:_maintenance:490
    2014-04-28 19:51:53,160 DEBUG    env_loc      Item env.location.day = True via Logic None None -- item.py:__update:363
    2014-04-28 19:51:53,337 DEBUG    Scheduler    env_loc next time: 2014-04-28 20:21:53+02:00 -- scheduler.py:_next_time:289
    2014-04-28 19:51:53,359 DEBUG    Scheduler    sh.gc next time: 2014-04-29 02:04:00+02:00 -- scheduler.py:_next_time:289
    2014-04-28 19:52:00,461 DEBUG    env_stat     Item env.core.memory = 13406208 via Logic None None -- item.py:__update:363
    2014-04-28 19:52:00,471 DEBUG    env_stat     Item env.system.load = 0.31 via Logic None None -- item.py:__update:363
    2014-04-28 19:52:00,916 DEBUG    Scheduler    env_stat next time: 2014-04-28 19:57:00+02:00 -- scheduler.py:_next_time:289
    2014-04-28 19:52:09,675 DEBUG    Main         knx: 1.1.14 set 3/1/2 to 00 -- __init__.py:parse_telegram:181
    2014-04-28 19:52:11,388 DEBUG    Main         knx: 1.1.50 set 3/2/1 to 00 -- __init__.py:parse_telegram:181
    2014-04-28 19:52:51,266 DEBUG    Main         knx: 1.1.15 set 3/1/4 to 076c -- __init__.py:parse_telegram:181
    Der Test mit sh.EG.Wohnzimmer.Decke(1) schlägt fehl.
    WINSCP setzt folgende Fehlermeldung "Der Server sendete den Befehlsbeendigungsstatus 2"
    Starte ich smarthome.py -d kann ich nichts mehr machen, bis die Applikation auf einen Timeout läuft ? Das Debug habe ich nachträglich aus dem Log Ordner kopiert, nachdem ich mich neu verbinden musste.
    Danke für die Unterstützung
    Hans M.
