Querying presence detectors
    HS/FS Querying presence detectors
    Hi.
    I am trying to query my presence detectors so I can know which rooms are occupied. I have several distinct presence detectors: Jung 3360, Theben 330 and Gira (non KNX connected to a binary input).
    I have created several group address that I've added each of the outputs from the sensors (or the correct binary input slot on the non KNX ones).
    I then added each one to an HS switch to check their status.
    The problem is that although I made everything the same way, some sensors do trigger and others don't. The Jung ones trigger the HS switch... the others don't. All of them trigger the corresponding light when I pass or enter the room so the sensors are working fine.
    What am I doing wrong?
