But I was referring to the
Experte/Stammdaten/Kommunikationsobjekte/Intern
and there, the "Status byte" is defined as "8-Bit (0..255/EIS 2,6)". Isn't that an integer ?. Also, the title of the line is "Datentyp", sooo
Thats right, but I think this is only used for the iKO and not for the internal variables used by the Bausteine. Its a little bit like the "Variant" type in VB...
Well, I'm collecting a terrific amount of experience these days
I know what you experience with getting this kind of experience...
