More than 1 group addresses?
    KNX/EIB More than 1 group addresses?
    Hi.
    I have a KNX presence detector (theben Sphinx 331) that I use to light up a room. I've added the 'switch on motion' object to another group address but this never gets updated. Can't I use more than 1 group address for the 'switch on motion' object?
    I have the same problem on the binary inputs. What am I doing wrong?
    Hi Mike
    It can only send to one Group Address, but it may listen to more than 1. That's a general KNX behavior.
    Cheers!
    Martin
      kropfm,
      Thanks for the reply.
      So... what should be the proper implementation if I want a sensor to light up a room but I also want to monitor it's state?
        well you may use the status object of your switch actuator. Or simply listen to your switch on motion Group Address.
          Thanks!
          I'll do that
