Out of order mSATA Gira HS4 :(
    HS/FS Out of order mSATA Gira HS4 :(
    Guten Tag, meine Freunde!
    Ich habe mir die Mühe - nicht in Ordnung mSATA meine Gira HS4 (hw 4)
    Ogromnoaya bitte - wenn jemand bei der Hand Gira HS4 und haben die Möglichkeit - zu entfernen, bitte Bild mSATA mit dem Dienstprogramm WinHEX und teilen Sie es mit mir.
    Ich würde sehr dankbar!
    Bitte helfen Sie!
    Ich danke allen, die zu der Entscheidung der meine Probleme reagiert!
    Please try to ask in english. Your post seems to be translatet automatically. I can't unterstand it.
      So it is, I used a translator. Thank you very much for your review.
      And so, back to my problem.
      Out of order mSATA Gira HS4.
      If someone is at hand Gira HS4 and have the opportunity, I beg you to remove the image using the program WinHEX
      I beg you!
      I will be very obliged for the assistance in solving my problem.
        The partition image is included in the Homeserver-Software which you can download at ??????????????????? ??????? Gira: KNX/EIB, ???????????? ??????????, ???????????? ??????, ????????????, ??????????? ?????, ?????????????.
        You can upload the software via RS232.
          MarkusS, thanks for the tip!
          I know it, and in my case, is not the solution. In my case requires replacement mSATA.
          As a result, I can not restore the regular means Gira HS4
