Webpage query and evaluation
    HS/FS Webpage query and evaluation
    Hi.
    I am trying to figure out the webpage/IP evaluation in HS.
    I couldn't find any example and all the testing I've made got absolutely no results.
    I am trying to achieve two simple tasks:
    1 - Post a value to a webpage. Example: http://host:ip/mypage?value=x
    2 - Get a response from an IP device. Example: Get power status from dreambox: http://<dreambox_ip>/web/powerstate
    1 - I've created a query/evaluate entry in HS. I've set the host ip and port. I tested the option 'send data blocks' and I am sending 2 blocks: "/mypage?value=" and the object value as text. Didn't work.
    2 - Set Ip and host. Send http calling to "/web/powerstate". In the reception added a regular expression to catch the 'true' or 'false' and pass it to a switch. Didn't work either.
    Can someone point me in the right direction?
    Thanks.
    Regards,
    Mike
    https://knx-user-forum.de/downloads.php?do=file&id=442
      Thanks.
      Will look into it.
