Hello gentlemen.
I'm sorry that I ask the question in English, but translating the German by google translate does that posts really not able to understand anything.
I have a problem with the activation temperature in my BJPRION 3.5 TFT panel. display namely, how do I activate the auto switch on or off actuatur ABB VAA / S 12 by a thermostat built into the panel (Temperature sensor for bus system 6352-860-101}. With my settings, everything works correctly if, that is, setting the temp. comfortable valve is opened and when changing to night or standby valve is closed when you change the comfort temperature to a higher or lower as much work correctly. problem appears then that the change in temperature at a given valve should be closed or open or 2-byte signal outpout thermostat {!} should be sent to ABB switch Actuator VAAS 12 and close or open the valve. Sorry but the RTC application settings there is no such object which is 2 byte so that the object sends this signal? enclose a snapshot of the settings screens RTC. I'm grateful for the tip. Regards Darek.
